Old 02-23-2013, 09:40 AM
1m1 1m1 is offline
Default Opening large sessions - beachball
I'm doing a job where I am recording several songs back to back on the same timeline in the same session. It's about 72 tracks at a time, and the session has about 20 pieces in succession that are about 30 seconds each. When recording the system works great, no sluggishness at all. I can record, stop, then record again, stop, play, etc all without the session hesitating. The issue is when I close the session and then reopen it. It takes about a minute before I can get it to play... this happens both with the disk cache set to normal, and I've tried both 20GB and 10GB settings. I'm not sure what the computer is busy doing during this minute. The task window doesn't show anything going on.
Any suggestions on how to get it to be responsive when opening a large session?
I'm running 10.3.3 on a 2010 Mac Pro with 40GB of RAM. HD3 system.
Old 02-23-2013, 05:55 PM
Question Re: Opening large sessions - beachball
There isn't any kind of modal window that appears during the session loading process that indicates what is going on? Nothing that says activating inserts or shuffling DSP or anything else whose exact text escapes me at the moment?
Old 02-23-2013, 06:01 PM
1m1 1m1 is offline
Default Re: Opening large sessions - beachball
No, no window at all. I hit Spacebar, the audio doesn't play, the cursor doesn't move, then after about 5 seconds the beachball appears and stays for about 45 seconds. After 45 seconds the beachball disappears and the music plays.
Old 02-24-2013, 07:50 AM
Lightbulb Re: Opening large sessions - beachball
We are not talking about the same thing here. In your original post you wrote that the problem was with opening the session. In your response you are not writing about opening the session, but rather what happens after the session is open and you press play.
What is the size of your buffer? Are there any changes to the meters in the System Usage window while the SWOD is on the screen? I think Pro Tools may be trying to read everything in the session before playing. You may want to break each song into its own session and see if that makes a difference.
Splitting large sessions into smaller sessions brandondurham Tips & Tricks 2 10-06-2013 09:02 AM
Bug in PT10 opening large sessions? derF macOS 2 05-25-2012 12:18 AM
Very large sessions nosfoe Pro Tools TDM Systems (Mac) 15 12-11-2009 02:21 AM
opening a session with a large I/O on my mbox? spaids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-06-2008 09:27 AM
Long beachball when saving MXF-sessions revisited Frank Kruse Post - Surround - Video 4 03-02-2008 03:07 PM
