Old 05-24-2012, 12:51 PM
greenetunes greenetunes is offline
Default I/O question Motif Rack ES & Eleven Rack
Hey all, I looked around on the site here and saw some similiar threads and tried different things.... but here's my situation.
I have an Eleven Rack, works great - been using it for six months now - recording vocals, guitars, using the VI's for synth sounds (have a Alesis Q49 - 49 key midi controller - connected) etc.. I just purchased a Motif Rack ES (yes, it's older but I love the piano and strings sounds and didn't want to fork out thousands for a great sounding piano/orchestra software).
My routing is this -
Q49 midi out to Eleven Rack midi in
Motif usb to Eleven Rack (midi in/out carried through the usb)
Motif l/r out to Eleven Rack l/r line in
Eleven Rack master out to speakers
With Pro Tools open I can press the Q49 and see midi data lights AND see the sound is getting to the instrument channel. I can plug into the headphone jack of the Motif and hear sounds. I hear no sound from the Eleven Rack (as far as the Motif goes.... I can play back and hear instruments that had been record to the songs previously)
Any thoughts??? (Sorry for the long post)
Mac OS X v10.13.6
iMac late 2013 2.7 Ghz, 8 MB RAM (I know... I'm low on memory)
ProTools 2018.12
UAD Apollo - Eleven Rack
www.rongreenetunes.com
www.facebook.com/rongreenetunes
Old 05-24-2012, 03:27 PM
Default Re: I/O question Motif Rack ES & Eleven Rack
After thinking... is it possible that since the motiff is not actually an "instrument" in pro tools that I need to record the midi data, make sure it's exactly what I want and then record the motif as audio????
thoughts?
Mac OS X v10.13.6
ProTools 2018.12
Old 05-24-2012, 06:39 PM
I'm a but foggy on your setup, but I'll take a stab at it. Go to the MIX window and select(under Mix Window Shows) the Instrument option. That will add a row of boxes at the top of the MIX window tracks. Assuming you use only a stereo instrument track, that top box should show the Motif as the desired instrument. Down at the bottom of the Instrument track, there is the same INPUT option as with any kind of track, so it should be set for the 2 line inputs where the Motif audio is patched. That SHOULD make it all functional as soon as you put the track into record, or record-ready. When you enter record, your midi(as played from the keyboard controller) should be causing the Motif to make sound and it should be heard thru the instrument track. Once that works and you get the midi edited to perfection, you may want to print audio, which can be done in a few ways. 1-put a stereo AUX send on the instrument track and send to a new stereo audio track(set to the same bus as the send), 2-set the instrument track output to feed the audio track, or 3-add your stereo audio track and set its input to the same pair fed from the Motif. Have I helped or confused
Old 05-25-2012, 03:31 PM
Albee.... I'll give it a shot this weekend (between gigs) and let you know how it turns out.
I now it's probably something stupid I'm missing But thanks for the help
Mac OS X v10.13.6
ProTools 2018.12
Old 05-27-2012, 07:47 PM
flommer flommer is offline
This doesn't seem right. Shouldn't even be possible based on the connectors.
There are a couple things you can do that should work:
Since the Q49 is just a controller (does not receive MIDI for any purpose) you can just connect Q49 MIDI out ---> 11R MIDI in
and since the Motif is "just" a sound module (for the most part, unless you are using it to play back MIDI sequences or something) you can just connect the 11R MIDI out ---> Motif MIDI in
Or you can do the better option which is to connect both devices to your computer via USB (the only way the USB ports should work) and then make sure your MIDI setup on your computer is seeing everything correctly. Usually it's easy to see right from Protools if the computer OS is recognizing any connected devices.
Your audio routing should be OK.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
need help setting up protools 8 le with motif rack and trition rack(so newby to this) BeatBoy19 MIDI 0 06-01-2011 10:38 PM
Eleven Rack & 003 Rack+ question deadshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-29-2011 12:14 PM
question about PT and Motif Rack.. m4ca General Discussion 1 12-17-2008 11:39 AM
