Old 12-13-2010, 11:42 AM
batchmister1 batchmister1 is offline
Default DAE is low on memory (error #-7053) HELP!!!!!!!!
plug-in could not be made actie becuase DAE is low on memory (error #-7053)
Pro Tools software version: Pro Tools 6.8 M-Powered
CPU: Intel Pentium 4
Processor spped: 2.8 GHZ
OS version: Win XP SP 2
Motherboard make/model: Intel D865GBF
Chipset: Intel 865G.
Ram:1gb
Hard drives: Internal 200gb. External 300Gb
Old 12-13-2010, 11:07 PM
Fjaertorslovaark Fjaertorslovaark is offline
Default Re: DAE is low on memory (error #-7053) HELP!!!!!!!!
Hi batchmister.
I noticed that you have 1gb of RAM. In my mind your error is basically saying "I need more RAM".
You can free up small amounts of RAM by making sure no uneccesary programs are running in the background (using the task manager). But I don't think this is enough.
I would advise you to upgrade your system. If you can't afford to do so, you should at least upgrade the RAM. I personally run into issues with any less than 4GB of RAM. Depending on the plugins that you use, you might be able to get away with 2GB.
dae error -7053 kelsey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-29-2008 08:36 PM
LOW DAE MEMORY ERROR 7054/7053 cinetj Pro Tools TDM Systems (Mac) 1 02-28-2008 03:55 PM
-7053 error humpback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2005 11:55 AM
DAE error 7053 Mike Turner Pro Tools TDM Systems (Mac) 2 06-20-2002 08:17 AM
'DAE low on memory #7053 ??? Soundworks UK Pro Tools TDM Systems (Mac) 7 05-06-2002 10:05 AM
