Old 07-30-2002, 06:06 PM
Allan Speers Allan Speers is offline
Default Just got HD: DAE ERROR -7053 HELP!
I just got my HD system connected.
I opened a pre-existing session. No problem opening it, but when Ihit "play" I get DAE ERROR -7053.
The computer doesn't crash, but the session doesn't run. It just sits there.
Here's my set-up:
HD-6 in a 13-slot magma chassis.
192 DIGITAL I-O ("D-I-O")as my main interface (my 192 analog I-O has not been delivered.)
Apogee AD8K for analog I-O, connected via AES (NOT the legacy port) Wordclock from Apogee to the 192 D-I-O.
888-20 connected to the D-I-O's legacy port. Superclock from the Apogee to the 888-20.
In Protools' Hardware-set-up:
The Hardware set-up shows a choice of 888-24 and 882-20, but I have an 888-20 !!! I used “ 888-24” since this was the only way to see four AES in-outs. is this OK?
ALSO: This 888-24 choice doesn’t include superclock in it’s “clock” options. -so I selected “wordclock.” Is this OK?
there are other ways to hook this all up:
1: clock from apogee via AES
2: Apogee AND 888 connected to the legacy port (but then what becomes the master clock?)
Regardless, My D-I-O is currently recieving clock from the Apogee, and the Protools software is set accordingly. I SHOULD be able to run, no?
Thoughts? -any thoughts at all, I am in a bit of trouble here! I talked to three seperate techs at Digi, and they didn't know what was wrong. the above is their best guess at proper hook-up.
I will be trying other permutations now, but NAY ideas would be most appreciated.
-Thanks.
Old 07-30-2002, 07:00 PM
Dutchmuzik Dutchmuzik is offline
Default Re: Just got HD: DAE ERROR -7053 HELP!
888-20 is NOT supported as legacy interface
Old 07-30-2002, 07:10 PM
You must be kidding! the 882-20 is supported, but not the 888-20? -but thanks for the info. No big deal as I will be trading it in for the 192 when it comes-in.
Regardless, the above can't be my problem. I removed the 888 from my hardware, and set the D-I-O to internal sync. Same problem. Arrgghh [img]images/icons/mad.gif[/img]
Old 07-30-2002, 07:53 PM
Update:
I read the Answer-base info. It said to check all hardware and also make sure all inits were in the system folder.
I see NO digi-init in my system.
I re-installed the software and STILL see no nit. has it been re-named? Could I possibly have a defective installer??? (never heard of THAT one)
Is there an area on the Main Digi site where I can download the latest init?
Old 07-30-2002, 08:17 PM
There is no Digi Init in HD with 5.3.1. Only DAE
Old 07-30-2002, 08:24 PM
Thanks, Dutch.
So, I'm still stumped.... I'm losing my mind on this one. help help help......
Old 07-30-2002, 09:19 PM
Why don't you try running an HD3 in your mac without the chassis and only connecting the 192 Digital I/O. Start from there and see if that works. Mine has been running perfect.
DAE is low on memory (error #-7053) HELP!!!!!!!! batchmister1 Pro Tools M-Powered (Win) 1 12-13-2010 11:07 PM
Maserati plugs=Dae error 7053 PhilBuckle Pro Tools TDM Systems (Mac) 3 01-30-2009 04:48 PM
dae error -7053 kelsey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-29-2008 08:36 PM
-7053 error humpback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2005 11:55 AM
DAE error 7053 Mike Turner Pro Tools TDM Systems (Mac) 2 06-20-2002 08:17 AM
