Old 03-05-2014, 03:48 AM
OdeToBob OdeToBob is offline
Default Re: Command 8 - Power up problems
Hey Nucelar,
I'm looking for some more info on building a replacement power supply for the command 8 as well. Can you point me towards a schematic or give a little more details.
Any help is greatly appreciated,
Bob
Old 09-07-2016, 09:35 PM
AKKKI AKKKI is offline
Thanks Nucelar,
Im live in japan. and sorry not good at Engllish.
But i want to say thank you very very much for Nucelar’s post.
Recentrly I got Digidesign Command 8 by Auction.
but power supply has not included.
So I was looking for some information about Command 8 Power Supply issue.
Thanks for Nucelar, I bought this trans.
Troidal tansformer,Primary:115 V ac, 230 V ac, Secondary:2 x 12V ac, 50VA
http://jp.rs-online.com/web/p/toroid...rmers/6719090/
So I soldered this
Brown& Green, Blue&Violet.
This two wire is for 100v AC (in japan)
If your country is 240v , this wiring must be changed.
Command 8’s power plug is 3Pin. 2 is center pin.
1=Red wire
2=Black&Yellow wire
3=Orange wire
Command 8 is starting up perfectly!
then Connect to Mac by USB.
and boot Protools 10.
Setteing by peripheral control.
Hope this can help someone!
Old 09-13-2016, 10:13 AM
given the vintage of the Command 8(same era as the 002 and the Control 24), I would suspect bad connections inside at a Molex connector(002 and Control 24 are notorious for this kind of issue). If it were me, I would open the unit and look for any Molex connectors(white-ish nylon blocks) and see if they unplug. If they do, then I would unplug and replug 5-6 times on every Molex you can get at. Then close it up and test(with fingers crossed)
Command 8 Power supply davpond Buy & Sell 2 12-06-2019 08:06 AM
Command|8 Power Supply? stuseattle ProControl, Control|24, Command|8 5 05-03-2012 04:33 AM
command 8 power issue? Dot ProControl, Control|24, Command|8 2 10-20-2010 11:01 PM
D-Command power cables ishur ICON & C|24 0 04-18-2006 06:24 AM
Command 8 Power Supply infernojs ProControl, Control|24, Command|8 3 10-03-2005 12:59 AM
