Waveforms Not Displaying Accurately. Anybody?
Hello Friends, I'm looking for a solution to this problem.
I started this album on PT 8 (HD) and then moved to another system (using the same drive) for overdubs (PT LE 7.4cs5). All previously recorded files are displayed accurately, however when I record new tracks, the waveforms are either not displayed or displayed inaccurately. A quick fix is to select the file area (edit or list) and select "Recalculate Waveform Overviews". However, doing this after recording every piece of audio is VERY tedious. I've also tried deleting the "WaveCache.wfm" file in each Song Folder AND deleting the Digidesign Databases folder AND "Save As". This worked on a couple of songs, but the problem has returned on all songs now. I realize there is a cs update, however I don't see anything about this problem in the description and I'm wary of updating mid-project. Any ideas or solutions you might have would be GREATLY appreciated. Thanks! Alex P.s. I've done many projects on this system as it is and have never seen this problem here. I believe it has something to do with either starting HD and moving to LE or starting in PT8 and moving back to 7.4 or both. --- OSX 10.4.9, Dual 2 GHz PPC G5, 4.5 GigRam, PTLE 7.4cs5, 002Rack www.alexgibson.name |
Re: Waveforms Not Displaying Accurately. Anybody?
Nobody has had this problem?
The only time I've had something like this is when making a new track and the default was not waveform but rather the selection above it.
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8 Pro Tools LE 8.0 - MPT2 - 003R |
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I updated to 7.4cs9 and it did not solve the problem...
Audiosuite processes also result in a waveform display absence. Scratching my head here... |
Maybe if it was recorded on a system that had the waveform calculation bug and then you moved it to something newer, the wave form never recalculated itself, so its still showing the wrong waveform. I had this problem when using PT MP 7.4. It was fixed for me in the 7.4cs.8 update. Waveforms that were recorded before the update did need to be recalculated.
Select tracks with messed up waveforms, open your region list and select "Recalculate Waveform Overviews", from the drop down menu. If that doesn't solve your problem then something else is going on, but I'm 99% sure it will. You can also delete the WaveShell file in the session folder. PT will recalculate the Waveforms next time you open it up. I do however prefer the "Recalculate Waveform Overviews" option. Its quick and painless, and inside a session, so you can see the results right away. Nick
www.TheSoundCoop.com www.youtube.com/TheSoundCoop PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs |
Does PT10 Sync Accurately to MTC ? | midifirst | Pro Tools 10 | 11 | 02-14-2012 08:38 PM |
How to accurately spot HD QT in Pro Tools? | Drew1 | Pro Tools TDM Systems (Mac) | 2 | 07-30-2006 12:16 PM |
Waveforms not displaying proper gain when bussing? | J.D. Andrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-02-2006 02:04 PM |
How to accurately measure levels to mixdown? | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2005 06:54 AM |
001 WILL NOT sync accurately to ADATs(I think) | Tex Tiles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-24-2000 08:33 PM |
