Old 05-25-2009, 11:05 PM
nod25 nod25 is offline
Default Plug-Ins Alias folder points to wrong folder???
I just checked my PT8 Plug-Ins alias folder. When I "Show Original" the Plug-Ins in this folder point to my PT7.4 Plug-Ins folder even though I did a clean install of PT 8. My PT8 Plug-Ins alias folder points to:
HD (Tiger) / Applications / Digidesign / Pro Tools / Plug-Ins alias (my 7.4 Tiger install)
1. Does this mean my install of PT8 is accessing my PT7.4 Plug-Ins?
Where PT 8 was clean-installed, it contains only PT8 install Plug-Ins:
HD (Leopard) / Library / Applications Support / Digidesign / Plug-Ins
2. What is going on?
Thanks to anyone who can shed some light on this...
Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance?
Old 05-26-2009, 03:00 AM
Default Re: Plug-Ins Alias folder points to wrong folder???
bumpity
Old 05-26-2009, 08:37 AM
flommer flommer is offline
I don't think the alias matters too much.. It's just there for convenience maybe? If you want to see if PT8 is trying to use your 7.4 plug-ins (on Tiger) then just move all your 7.4 plug-ins to the Plug-ins(unused) folder and see what happens.. My guess is that you would have been having problems if PT8 was using 7.4 plug-ins...
Let me guess.. You did a clean install of Leopard, but you imported files and settings.. Then you installed PT8 over that...? That's the only thing that I could think of that would leave behind an alias pointing to the Tiger volume. The PT8 installer might not have seen it as a problem, so it didn't overwrite it
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 05-26-2009, 03:43 PM
Thanks flommer.
Clean install Leopard and PT8 from disc but I didn't import files and settings.
Good point.
Why is there a VSTPlugins folder under my Avid folder? EnjoyRC Windows 1 10-28-2011 11:55 AM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
"fade file" folder out of my session's main folder! preachers Pro Tools TDM Systems (Mac) 1 03-11-2009 09:08 PM
Want to reduce size of session folder. What am I doing wrong?? JChance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-19-2008 01:38 AM
Digidesign folder in OS X's Library Folder Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2001 08:00 PM
