How to obtain demo authorizations for DINR
I'm trying to obtain a demo authorization for DINR or NoNoise, I seem not to be able to find a procedure...
Any Ideas? Thxs |
Re: How to obtain demo authorizations for DINR
Shameless bump!!!
I have the demo authorizations on my iloks for both, however it doesn't work, maybe the demos are not for PT7... any light on this? |
Try installing the plugins again and when you load PT it should ask you to go through the auth procedure, and if the auth is in the ilok you should be good to go! providing the auth and the plugin version are both for PT7 Where did you get the DINR demo ilok auth from? Chris
ehem...demo mode is (at the moment) lifted on Digidesign Plug-ins in PT7. until a Pace issue is solved.
So if You wanna demo them, You have to revert to PT 6.x to test them. Those demo auths came with the HD Pack plug-ins back in the days. BW |
I just made my upgrade to HD and only got PT 7.1
I have a project which noise is an issue and would like to try this plugs to see which one works better on the particular situation in order to buy... I have the demo authorization on my iloks, but I guess is not for 7, I tried running the authorization, and it reports that I have a demos authorization but the plugs don't load. Is a pity that demo is not available |
How does one obtain Pro Tools HD? | ianbee | macOS | 2 | 10-28-2013 06:56 PM |
DINR Demo Not Showing up in Plugs Menu | Styles Bitchly | Pro Tools TDM Systems (Mac) | 1 | 01-18-2008 09:16 AM |
How to obtain demo authorizations these days? | PastaViking II | Pro Tools TDM Systems (Mac) | 3 | 03-31-2006 08:50 PM |
Where can I download DINR DEMO?? | M15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-24-2005 08:52 AM |
DINR - Sonic NoNOISE Special Offer for Registered DINR Owners | ProdInfo | General | 0 | 04-28-2003 11:31 AM |
