ptle7.0cs1 firewire/dae error 002r
"dae is having trouble keeping up. your disc may be too slow or fragmented. a firewire disk could be having trouble due to the extra firewire bandwith or cpu load. (-9019)
DAE error 87" note: my computer was running perfect with pt 6.4 cs 9, this just started after the upgrade. i figured it could be viruses/spyware slowing down the pc, so i backed everything up, and completley whiped the computer, and fresh installed windows xp, then installed sp 2. i also defragmented all drives, ran virus scans, etc. even if pt is the only application running, and the network is disabled, i still get this error. i cannot even play a milisecond of music before it cuts out. ive messed with the buffer, reinstalled the firewire drivers, and my harness is fine. system: e machines, amd athlon 2200 (1.79 ghz) processor, 2 x 512 DDR-SDRAM, 180 gig hard drive (2 separate drives, one is partitioned into 3 areas, one of them is windows, the other is storage, the last is for pro tools sessions, the other separate drive has pro tools installed on it), Chipset : VIA P4M266/KM266 (VT8375) |
Re: ptle7.0cs1 firewire/dae error 002r
Try all of the suggestions in the General Troubleshooting thread
yeah,,,that made it worse... now it blue screens when i click on the pt icon to open it. doesnt even start now
Blue screens on startup are usually the cause of out of date PACE interlok Drivers. Update them. That's covered on the compatibility page, which is the very first item on the troubleshooting page.
Also, one of the items in the General Troubleshooting thread: Quote:
updating interlok takes me back to square one with the original problem: pt opens, but wont play, and gives me the firewire error.
SiSoftware Sandra
System Host Name : STUDIO User : Punch Domain : MSHOME Processor Model : AMD Athlon(tm) XP 2200+ Speed : 1.80GHz Model Number : 2200 (estimated) Performance Rating : PR2603 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Phoenix Technologies, LTD 6.00 PG System : eMachines, Inc. L7VMM2 Mainboard : KM266-8235 Total Memory : 992MB DDR-SDRAM Chipset 1 Model : Elitegroup Computer Sys VT8375 ProSavageDDR PM266/KM266 CPU to PCI Bridge Front Side Bus Speed : 2x 133MHz (266MHz data rate) Total Memory : 1GB DDR-SDRAM Shared Memory : 32MB Memory Bus Speed : 2x 133MHz (266MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : S3 Graphics ProSavageDDR (Microsoft Corporation) Imaging Device : Creative WebCam NX Pro Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : WDC WD1000BB-00CAA1 (93GB) Hard Disk : WDC WD800JB-00ETA0 (75GB) CD-ROM/DVD : LITE-ON LTR-40125S (CD 48X Rd, 40X Wr) CD-ROM/DVD : SONY DVD RW DRU-810A (CD 126X Rd, 126X Wr) (DVD 16X Rd, 16X Wr) Logical Storage Devices 1.44MB 3.5" (A:) : N/A Central cpu (C:) : 6.8GB (1.5GB, 22% Free Space) (NTFS) Storage (D:) : 9.8GB (6.4GB, 65% Free Space) (NTFS) Studio (E:) : 77GB (33GB, 44% Free Space) (NTFS) Music (F:) : 75GB (46GB, 61% Free Space) (NTFS) My disc (G:) : 3.9GB (CDFS) CD-ROM/DVD (H:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : USB Composite Device FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Keyboard : HID Keyboard Device Mouse : PS/2 Compatible Mouse Human Interface : HID-compliant device Human Interface : HID-compliant consumer control device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Realtek AC'97 Audio for VIA (R) Audio Controller Printers and Faxes Model : Auto HP DeskJet 722C on LIVING-ROOM Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2, v.2082) Network Services Adapter : Wireless-G PCI Adapter |
well, i just go 7.0, figuring that might solve the problem. same issue. only difference is some box pops up when i open pt, saying i need to update the firmware...takes forever...then crashes the program. is there anyway to manually update the firmware? maybe thats the issue.
The firmware update is done through the program; there's no other way that I know of. Complications with the firmware update have been linked to troublesome firewire connections, though. You may want to try a different firewire interface, specifically one of the qualified ones. Also, make sure you are disabling your wireless network card when you are using PT. It has been known to cause problems (that I can attest to first hand).
yeah i do disable the wireless card. but i dont get it. before i tried this update, i could have the wireless installed, checking mail online or sumthing, and have tons of programs open, with no lag. and this was the same firewire card. why all of a sudden would it decide its not going to work with that card?
002R Firewire Bus Reset Error/Recall Inquiry | n.rozka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-25-2008 09:09 PM |
PTLE7.1, Live 5.2.2, 002R, M-Audio 192 and ASIO | James Drake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-12-2006 09:59 AM |
002R, PTLE 6.4 to PTLE7.0??? | Ryan Taylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2006 09:17 PM |
Any chance for an upgrade to Digi 002R/PTLE7? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-04-2005 04:09 PM |
002R with firewire audio drive error -6085/-6086 | mik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-07-2003 10:49 PM |
