Old 02-10-2005, 03:26 AM
xsdata xsdata is offline
Default Cubase command 8 midi map here
Well it took me a while so to save you some time here is the XML document you load into cubase to get the command 8 working. I even mapped out some transport buttons because the normal ones don't send midi cc data in standalone mode.
here is what you need to do
1. download the xml document
2. Put the command 8 into standalone mode
3. Open cubase and go to the devices menu , select device setup and click import. this is where you import the XML file for the command 8
now you can see that the Faders have been mapped to midi chan 1-16 (press bank) , the panners have been mapped, solo and mute has been mapped and all send data back to the command 8!
The transport buttons are set out above the pan encoders. RTZ, REW, FWD, STOP, PLAY, RECORD in that order!You can even go into the midi edit on the command 8 and set the buttons from latch to momentory so they act like the real thing ! I hope this helps some people . Another good idea would be to set faders 1- 8 to midi and 9-16 as Vst so you can control both from the command 8!
Peace
Old 02-10-2005, 03:31 AM
Default Re: Cubase command 8 midi map here
whoops here is the link!
http://www.members.optusnet.com.au/xsdata/c8.xml
right click and save as
Old 02-10-2005, 07:42 AM
silverlode silverlode is offline
This is great! I don't use Cubase, but I appreciate the time you put in to share this with the world. I am planning on working on a map for Logic soon.
Thanks again.
Old 02-11-2005, 04:59 AM
Sofine Sofine is offline
Nice one. Thanks!
Simon
www.simonfine.ie
www.bubblegumstudios.com
Old 02-27-2005, 09:01 PM
francois's Avatar
francois francois is offline
Thanks I'll try it with Nuendo
Francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 04-04-2005, 01:57 AM
baruch baruch is offline
Does anyone know of a midi map or a driver for DP4.5 (Digital Performer) and the Command 8 ?
I have been trying get my Command 8 to control DP and have had no luck.
Old 07-15-2005, 01:33 PM
Randirainbow Randirainbow is offline
XSDATA....Thank you for your Command 8 midi map. How do I download that file as an xml file? Or can I just copy it as a text document?
" What hump?"
Old 07-22-2005, 09:53 AM
Bump!
" What hump?"
Old 07-22-2005, 11:10 PM
juanit0 juanit0 is offline
Just rightclick(PC)/ctrl+click(mac) and save as to your desktop.
Then in device setup you can add a generic remote control and load the .xml file to it. Good luck, I personally gave up and returned the unit, worth nothing outside of Pro Tools...
Old 08-30-2005, 11:54 PM
DigiSupportAus DigiSupportAus is offline
Hi Guys,
Did anyone get this to work???? To you need to set somthing on the command|8 when in stand alone mode????
Any help would be great!!!!
Thanks guys.
G
Command 8 And Cubase shlomiabo ProControl, Control|24, Command|8 6 11-01-2011 07:51 AM
xml command 8 for cubase 5...help...i can't find it... celestian ProControl, Control|24, Command|8 0 07-09-2009 06:08 AM
Command 8 with Cubase 5 with Vista...help.... celestian ProControl, Control|24, Command|8 0 07-02-2009 04:53 PM
Digidesign Command 8 with Cubase Studio 4 - HELP!!! stevethebeeline4 ProControl, Control|24, Command|8 0 05-17-2008 07:52 AM
Command 8 and Cubase headclouds ProControl, Control|24, Command|8 1 12-05-2004 05:51 AM
