alternative to bounce to disk
if i wanted a more decent dithering should i send my signal out a master fader, via lightpipe or spdif, to an external cd burner?
Re: alternative to bounce to disk
The way it was explained to me, yes, you should set up a master fader when you are going to bounce. All of your
tracks will be routed through it by default. I set up a stereo master fader, command-shift-n for new track, choose stereo and master fader. Then, as in insert on the master , choose stereo POW-r dither 16-bit, either noise-shaping 1, 2 or 3. Don't ask me what the difference is in 1., 2, or 3 -- and if anybody out there knows, please join in. Does it have something to do with how the added dithering noise gets allocated, in various frequency ranges??? Your ear is probably your guide here. 1, 2, and 3 may sound slightly better or worse on various kinds of music, classical, rock, jazz. I am guessing you have to have Bob Katz's ears to hear the difference. then you bounce to disk just like you would regularly, to CD with 16-bit, 44.1 aiff. The dither is supposed to do its thing then.
G5 -- dual 2 gHz -- 2 gigs ram -- OS 10.4.6 |
Alternatively, you can record to something like a Masterlink, ADAT device, etc. In any case, dither the final mix from protools. If you have Waves L1, L2 or L3, I would recommend those over the audiosuite ditherers. If the external recording device has good quality dither capability, by all means, bounce at 24bit. IMHO
Share the gift gifted to you |
Create a master fader, insert POW-R as the last plugin. Listen to each of the noise-shaping methods (1,2,3); see if you hear a beneficial difference. Bounce to disc; set your file format to 16 bits, end of story.
There is NO better dither alrogithm than POW-R in my opinion; there are some that are equally as good on certain sources, but none better. D |
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 12:41 PM |
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade | AllThingsMusicStudio | macOS | 0 | 06-28-2012 07:16 PM |
LE's Bounce to disk vs. Reaper Render to disk | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-16-2009 04:49 PM |
alternative to bouncing to disk? | Audio Princess | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 10-31-2005 04:52 AM |
Is there any alternative to the real-time BOUNCE? | Damon Hoydysh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-09-2004 01:49 PM |
