Old 03-21-2020, 06:43 AM
Default Re: DAPS out to Dante VS?
Originally Posted by GuidoHelbling View Post
I have not found out if it's possible to run for example the RTW meters stand-alone and catch the output dante channels. As far as I know, it's not possible on the same machine.
That's what Dante Via is for (it turns any program into a Dante device for routing on the same machine or an individual app to the external Dante network, so you can patch any app via the Dante Controller or the Via app). It's very cool but I'm not sure if it can do more than stereo. Haven't tried yet.
Worth a try.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 03-21-2020, 07:44 AM
smurfyou smurfyou is offline
Worth a try.
Dante Via is supposed to support 16 channels.
~Will
Old 03-21-2020, 08:28 AM
improvpwnd improvpwnd is offline
You can use Source Nexus and Loopback to do this.
Old 03-21-2020, 03:38 PM
paulo m's Avatar
paulo m paulo m is offline
Hi Paulo
I haven't really worked with this setup. For working with DAPS and PT on the same machine, I have decided to use the renderer with the send and return plugin. This has the advantage, that I have all the audio channels 'in the box' in pro tools. Specially because I want to use my RTW meters and analizers in the pro tools master sum.
By sending objects by the dolby atmos bridge, pro tools is like a multitrack machine and the renderer the master instance like the multitrack recorder. Because then the renderer will give out the audio to the core to dante, I'd use a second machine to catch the dante channels and monitor the levels.
About latency to pic: you could set a master-dalay for pic or audio to get both in sync. But I cannot find it right now, have a look in the renderers manual.
Guido
Hi Guido, thanks for the update.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 03-22-2020, 02:27 AM
GuidoHelbling GuidoHelbling is offline
Worth a try.
Hi Frank,
Good point, will check that again. I have Dante Via, purchased it in a bundle with DVS. I had massiv problems with Via, stuff like: it is working then it isn't. so it made me crazy but to be honest, haven't really tried it seriously.
I'm sure, there will be enought time in the next days to check that.
And yes: there is a 16ch i/o in Via. I forogot the name but it can be activated.
Dante an latency to picture: would be interesting to hear your experiences. How would you measure that? Run beeps to picture-marks and see/listen if it's in sync?
Guido
Pro Tools Ultimate 2023.6 with Dante, MacPro 5.1 12 Core, 32 GB RAM, Mac OS 12.6.3 with OpenCore, Decklink SDI 4k, Dynaudio Air 15 and bm5a mk2 as 7.1.4 Monitoring
https://www.avosound.com/en/
https://www.guidohelbling.com/
HTML code is On
HDX with Dante Via freakhouse Pro Tools HDX & HD Native Systems (Mac) 38 09-18-2021 06:18 PM
Ultimate-Dante or hdx-alone pov DetroitT Pro Tools HDX & HD Native Systems (Mac) 2 01-31-2020 08:09 AM
Dante issues with PT's freakhouse Pro Tools HDX & HD Native Systems (Mac) 6 07-30-2019 11:44 AM
DAPS Audio Bridge Input Limitation soundeditor76 Post - Surround - Video 2 06-21-2019 09:41 AM
Virtual Dante I/O tlinget Third Party Interfaces 2 01-17-2018 03:26 PM
