Old 03-29-2024, 08:15 AM
Default Re: Minimizing elastic audio artifacts
Originally Posted by camshash View Post
What sources are you using X-form on? Every time I use x-form it sounds very phasey and 'digital' for lack of a better word, however there are no lumps in the audio like I'll get from all the other algorithms. What version pro tools are you running? I experienced the same thing with elastique-pro in 2024.3, very phasey sounding.
Is it possible there are other settings within the session/preferences that are causing elastic audio to not work properly? I had one song pre-mix with very little if any plugins/automation and elastic audio worked flawlessly, but on a session in post-mix stage elastic audio failed
For changing the tempo of a song, I use X-Form for everything except drums(gotta be very careful on multi-mic'd instruments). Often, if I have an acoustic guitar tracked with multiple mics, I will choose the best sounding single track and skip(Hide and make inactive) the other. Percussion stuff usually gets the Rhythmic option. Drums get Beat Detective(as a group) or I edit manually. There really is no single solution that always works, so be flexible and experiment. And look into a demo of Serato Pitch 'n TIme
Old 03-31-2024, 12:04 AM
camshash camshash is offline
Gotcha and I've already used my free trial of serato pitch n' time, though I did not try it's TCE feature only the pitch shifting part which worked very well. Is the plugin worth the $800 in your experience, especially with the newer zplane elastique included in the current pro tools?
MBP 16" 2021 M1 Max 32gb
UAD Apollo x8p
Focusrite scarlett
Pro tools 2022.12
Old 04-01-2024, 02:19 AM
huzzam huzzam is offline
Originally Posted by Rich Breen View Post
FWIW, EA is great for tweezing an individual track to a grid or to another instrument, but I wouldn't use it for this particular task; to compress/stretch everything in a session by a specified amount I'd use one of the dedicated TCE algos on a per-track basis; Pitch 'n Time or Soundshifter are both capable of good results - I've also sometimes used Zplane Elastique (audiosuite) and Izotope Radius with good results.
I agree that per-track re-timing is the way to go. And for percussion tracks, I'd use Beat Detective 100%. Just make sure you have any tracks that were recorded together grouped :)
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Elastic Audio & Artifacts Bfearr Windows 7 12-02-2015 01:20 PM
Elastic Audio caveats. artifacts. sweetness Pro Tools TDM Systems (Mac) 10 11-29-2009 01:43 PM
Artifacts with Elastic Audio? BreenMachine Tips & Tricks 5 09-20-2009 02:29 PM
> Elastic Audio - Artifacts Howardk Pro Tools TDM Systems (Mac) 11 03-16-2009 10:16 AM
Unusual artifacts when using elastic audio on a stereo track 2fly Pro Tools TDM Systems (Mac) 4 06-30-2008 04:46 PM
