Old 07-01-2014, 12:36 AM
Raggi Raggi is offline
Default Tips for buying a used C24
Hi.
I am about to purchase a used C24 from end of 2009 and would like som pointers on what to look for and check before the final payment :)
Obviouse check the faders to see if any are defective/moving slow and run the console in Vegas mode to check all lights and movements.
Also open a session and run it.
Any other things you would suggest me to check?
Old 07-01-2014, 12:46 AM
Default Re: Tips for buying a used C24
If you care about the mic preamps, monitor section and built in mixer you need to check all of those carefully.
Old 07-01-2014, 02:13 PM
and, does it include all the cable package(or do you already have what you need)? Lots of 8 channel DB25 cables are required to run the beast Also, you MUST have a good earth ground in your studio or the faders may give you fits.
Old 07-02-2014, 02:32 AM
HI.
Thanks. My plan first i to use it as a control surface and then connect my Focusrite LS56 out->into the C24, but I have to buy the cables first. I don't think they are in this package. Also connecting my monitors and Headphone amp at a later stage.
Old 07-24-2014, 03:21 PM
John J. John J. is offline
Have them show you Vegas Mode to check fader motion and all leds.
MacPro 2.66 8 core • 24G ram • Lotsa Terrabytes
OSX 10.8.4 • MBP Core i7
C|24 • PT 10/11 HD • Reason 6
www.icedrum.com
Old 07-24-2014, 04:04 PM
Thanks. Yes I bought it and I had it for some days before paying to test it and everything works. No cables with the system. I bought 3 DB25-Jack to connect between the Focusrite Liquid Saffire 56, monitor and heaphone distribution.
The monitor, talk back, listen back works like a charm.
It's all good :)
Old 07-25-2014, 05:36 AM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Raggi View Post
Thanks. Yes I bought it.....
how much if you don't mind us asking?
Daniel
Old 07-25-2014, 11:19 AM
YYR123: about 35.000 NOK. One dollar is about 6.22 NOK. If I get my calculator, is should be......hmm.... 5620 dollars. It's a 2009 model.
Tips on Buying a Used Pro Control (shipping weight etc) DaveSB ProControl, Control|24, Command|8 3 04-29-2007 08:35 AM
tips for buying DVD player with discrete audio out mtung Post - Surround - Video 6 03-13-2006 12:04 PM
Buying New Computer...I Some Need Tips..... sethbrand Pro Tools M-Powered (Win) 9 03-13-2006 08:50 AM
Tips on buying outboard gear under 500€/$ Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-06-2005 04:08 PM
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well xian$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-18-2003 11:53 AM
