Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 10-27-2018, 01:44 AM
anp anp is offline
Default Inserts..serial or parallel?
Hi
So are the inserts on inputs/outputs in serial or parallel. The manual I have doesn't make it clear. It says the Hardware Insert can be located anywhere within the chain so I'm presuming they are in series?
Thanks
Andy
Old 10-27-2018, 05:34 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Inserts..serial or parallel?
Yes they are in series.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 10-27-2018, 05:52 AM
anp anp is offline
Thanks
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
PT9 + 10 parallel on OSX? 10.6 or 10.7? janmuths macOS 5 02-06-2012 08:32 PM
Setup Help - W/Amp (diezel)- Serial or Parallel loop? & GCP DUlrich Eleven Rack 3 04-17-2011 05:31 PM
Serial Card and Serial ATA...Good Idea or NoCigar fifty8th1 Pro Tools TDM Systems (Mac) 7 02-09-2005 11:24 PM
More than 5 inserts in serial for chain of effects - How? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2002 09:26 AM
