Old 03-31-2005, 09:30 AM
tclash tclash is offline
Default Highly annoying 002 pops
So I am getting a batch of highly irritating (and loud) clicks/pops/thumps whenever I preview audio in an Audiosuite plug-in while running a 48k session. It happens both when I start and stop the preview. No problems with 44.1 sessions. Doesn't seem to matter what plug it is and the clock is set to internal.
Actually now that I think about it it also happens when I open a 48k session.
Anyone else seen this behavior? This is a fairly new system all around (DP 1.8 G5 & 002R). I did a fresh install of CoreAudio recently. Might it be the culprit?
Thanks for any advice.
Old 03-31-2005, 11:59 AM
alance alance is offline
Default Re: Highly annoying 002 pops
clicks and pops are usually a clocking thing. Do you have any other devices connected digitally?
Old 03-31-2005, 12:46 PM
Yes I do, but this happens whether they are on or not, and the noises come from the 002 main outputs.
It's almost like just uing the preview in Audiosuite is causing the clock to toggle back and forth.
Maybe I should try uninstalling Core Audio?
Thanks
Old 03-31-2005, 01:30 PM
Ducky Ducky is offline
Are there several regions being patched together that you are previewing? I don't think fades are being taken into account when previewing and it could be transition artifacts at the beginning/end of the regions. Just a thought.
Old 03-31-2005, 01:59 PM
No that doesn't factor into it. It makes the pops when I start or stop the preview.
Old 03-31-2005, 03:21 PM
Keith Owens Keith Owens is offline
you said it happens when you open 48k sessions, then the clock is still set for 44.1 sessions. Make sure the external devices and the PT clock are the same in the 48k sessions.
soon to be back at it again...
Annoying Pops and Clicks in Pro Tools bryanwilson2007 Pro Tools M-Powered (Mac) 4 02-22-2008 05:58 PM
Annoying Pops and Clicks after about 30sec. sforcash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-12-2006 02:00 PM
Highly disturbing groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-04-2005 11:27 PM
Random pops, crackle, and clips. very annoying WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-08-2005 07:33 AM
advice on this mix will be highly apprec. tantejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-09-2004 11:51 AM
