Old 12-28-2019, 08:49 PM
aaronbagby aaronbagby is offline
Default Missing an aux when I bounce to disk
Hello. I have the following issue perplexing me at the moment.
I have a session with all instruments feeding various auxes, which all feed a mix bus (127-128). All auxes are audible during playback, except the aux featuring my acoustic drum samples. It catches all of my SSD5 drum tracks, feeds them out to a master drum bus where it combines with some Linn LM1 samples, which then feeds my mix bus. Routing is sound, and I'm able to correctly solo anything all the way through the chain. But when I bounce to disk (yes, bounce source is set to Out 1-2) the acoustic drums are not there. I can't figure this out, and it's very important I figure it out ASAP. Thanks in advance for any help!
Old 12-29-2019, 01:54 AM
Emi's Avatar
Emi Emi is offline
Default Re: Missing an aux when I bounce to disk
Trash preferences, restart.
This is what I do when something weird happens. It usually works.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 12-29-2019, 02:59 AM
Teej Teej is offline
If that doesn't work, can you try a Commit or a Bounce of that aux before bouncing and use that as the source instead of the "live" SSD5 as a workaround? At least that should get you to the finish line and/or let you know if the problem is before or after that aux channel.
Old 12-29-2019, 04:43 AM
Another thing is is the routing being done by outputs of the aux tracks or via sends? If by sends then just use the regular output of the aux.
Jack
QAPLA!
Old 12-29-2019, 08:38 AM
And one more longshot....something you THINK is routed to a physical output just MIGHT actually be feeding a bus with the same name. I know that sounds convoluted, but I had it happen to me where everything sounded fine on playback, but the bounced mix was missing several parts. It turned out that my routing had gained a bus with the same name as my main output I deleted that bus path from the IO setup and reset those track outputs properly and all was good.
Old 12-29-2019, 09:13 AM
Originally Posted by albee1952 View Post
And one more longshot....something you THINK is routed to a physical output just MIGHT actually be feeding a bus with the same name..
^^^ This
Almost certainly a busing error - *carefully* examine your I/O setups (physical out and bus pages).
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 12-29-2019, 01:23 PM
Originally Posted by Rich Breen View Post
^^^ This
In my case, I never created a bus called Main Out L/R(which is the name of my main output path). Somehow, PT created the bus and in checking output routing, I discovered the bus on the list
Midi Bounce to Disk file Missing Notes stevenengle Pro Tools 2018 8 09-20-2018 10:14 AM
Bounce to Disk: Bounce to disk length is longer than my track on my time dijitalhorse Pro Tools M-Powered (Mac) 1 02-23-2016 06:27 AM
Missing video when bounce to disk --> Quicktime movie Jakob Clemen macOS 0 05-16-2011 02:02 AM
Some audio trks are missing when I bounce to disk J. Rivera Pro Tools TDM Systems (Mac) 33 05-19-2006 01:11 PM
6.7cs7 BIG Bounce to Disk problems - missing audio Farmer Dave Pro Tools TDM Systems (Mac) 2 01-22-2005 02:27 PM
