Old 01-29-2016, 05:59 AM
Marsdy Marsdy is offline
Default MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD
PT12.4... The keyboard commands to open the MIDI Editor and MIDI Event Editor are broken. The Window Menu flashes twice in quick succession but neither window opens. I've checked in OS X Preferences>Keyboard>Shortcuts but nothing is clashing. Note: I'm using an Apple British keyboard.
http://protools.ideascale.com/a/dtd/...79?submitted=1
Dave Marsden
UK
Old 01-31-2016, 12:35 AM
Default Re: MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD
Apologies for bumping this.
70 views and not a single instance of anyone else getting the same problem
This is a brand-new installation of OS X and ProTools 12.4 HD. Already done a couple of pref trashes.
Dave Marsden
UK
Old 01-31-2016, 03:11 AM
sam68's Avatar
sam68 sam68 is offline
http://duc.avid.com/showthread.php?t=375873
http://duc.avid.com/showthread.php?t=376483
Old 01-31-2016, 03:20 AM
Thanks. Not just me then! I did do forum search and a Google search of the DUC but didn't find anything!
Dave Marsden
UK
Old 01-31-2016, 04:04 AM
Jon_Atkinson Jon_Atkinson is offline
Hey Marsdy,
I know you're a Protools guru, so I don't want to suggest something really obvious (apologies if it's a Grandmother/eggs suggestion..!)
But is it possible that the MIDI editor is set to appear at the bottom of the screen (as opposed to a separate window), but then the editor size is set to zero...?
I'm not in front of my machine at the moment, but I've seen this (also not just with PT but with other apps)
I think when the MIDI window is set at the bottom of the edit window and then you double click on the line which would otherwise resize, it can effectively disappear....
I'll check that tomorrow when I'm back in the studio...
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 01-31-2016, 05:01 AM
Originally Posted by Jon_Atkinson View Post
Hey Marsdy,
Hi Jon
I don't think there is a keyboard command to open the MIDI editor pane of the main Edit window. I can't find one anyway! You can open it from the view menu amongst other places but there no keyboard command associated with it.
I'm pretty sure this is a bug. The keyboard commands to open the MIDI Editors are working if you use the = sign above the qwerty keyboard but not the numerical keyboard and it should do, or at least it did.
It's annoying because it's a hard habit to break.
Dave Marsden
UK
Copy and Paste in midi editor writes over other midi data elvolutionstudios macOS 1 07-07-2012 06:58 PM
Is it me or is SHIFT key broken in MIDI editor?? digidesigner Windows 9 05-23-2012 02:39 PM
Can anyone clarify 1) Midi Track Sizing, and 2) color coding Midi Editor Infiltrator Pro Tools 9 5 01-10-2011 07:53 AM
Can you trim MIDI regions from inside the MIDI editor window? emspace Pro Tools M-Powered (Mac) 0 07-06-2010 12:13 PM
Calling all that write/program midi drums by hand in the Pro Tools midi editor. Mikey Ace Virtual Instruments 2 10-05-2008 07:14 PM
