Pro Tools 8.0.1 - hangs at Structure or Hybrid after launching
Pro Tools 8.0.1, CRASHES AND PROBLEMS...?
Well maybe there is something else going on in my PC or Digi002 hardware (not likely as everything was working just fine.............) but I just downloaded Pro Tools 8.0.1 updater and after installing PT would not boot up! After running the installer, the app was loading plug-ins and kept freezing up on the hybrid.dpm so what could I do? I uninstalled PTLE8.01 and came back around again after deleting drivers/plugs etc and defraged, ran registry cleaners (blah blah bah etc etc...) and went to re-install PT8 and try to do a rebuild but now PT hangs on Structure.dpm and won't start! This is not good! not good at all! Anyone with a solid clue, please I need some guidance to get back in the game here. I am running XP PRO/SP3 with 4GB's Ram/ AMD Dual Core fyi. thanks |
Re: Pro Tools 8.0.1, a free software update that provides CRASHES AND PROBLEMS...?
if you dont use structure at all, or if its not that important to you, what you can do is remove it from your plug-ins folder by following this path:
"C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins" it could be that the structure.dpm file is corrupt. |
Are you sure you haven't let IE8 install? If so, that is likely your issue.
Hi Kory as described PT hangs on both hybrid.dpm & Structure.dpm.
Could both plugs corrupt so quickly? ********************************** Hi Tom yes I have IE8 installed but everything was fine before I ran the new Pro Tools 8.0.1 updater. Is this a known issue with only 8.0.1? Under pt8.0 everything ran perfectly as of yesterday |
This is a known issue with the latest versions of those plugins. Is it possible that you were using older versions when you were using 8.0?
The recommendation from Digidesign is not to use Internet Explorer 8 on any Pro Tools systems at the present time. I would follow that advice until they get it sorted.
Is Tamara Home? She was home before
Please uninstall IE8. Go back to 7. There are interactions that can differ with every installation. If for some reason you feel you will need a browser on your DAW, go get Firefox or Chrome.
Next time, save yourself a lot of aggravation by haing a backup plan. Mine is to clone the system drive to a spare drive before running any update. This way if the update goes sour(and I feel your pain) you can swap the drive and go back to work. Another otpion is to save a drive image that you can restore from. Axronis True Image is what I use but there are other options(even some free ones).
As indicated, the problem is with IE8 and reverting back to IE7 should fix it.
I've edited the thread title for clarity. |
Navigating to Browser tab in Structure hangs Pro Tools | unifunkd | Virtual Instruments | 54 | 06-06-2011 01:16 AM |
Hybrid & Structure are YELLOW in PT9 | spearson8 | macOS | 3 | 04-26-2011 07:36 PM |
Pro Tools 8 LE hangs after launching the DAE - restoring tracks: activating kicks | trendkill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-28-2011 07:46 PM |
Hangs on structure...... | hootist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-10-2010 11:56 AM |
GUI not visible for Structure with Hybrid | Andy Murdock | Virtual Instruments | 11 | 04-20-2009 01:27 PM |
