Old 12-27-2005, 09:59 AM
bigmarkus bigmarkus is offline
Default effects and aux sends
just wondering what the preferred choice of routing is for adding effects to a track. i used to insert reverbs, comps, eqs etc on every track, but now im getting into sending numerous tracks to an aux track with an effect inserted on it (i hear that using the same reverb on multiple tracks can help "bring them together").
question is; does one hardwire the dry tracks to the aux track (i.e. select the aux track as the dry tracks' output) or simply choose the aux track as a send on the dry track? i imagine the second option may allow for greater control of dry/wet balance.
Old 12-27-2005, 06:09 PM
Matt Whritenour Matt Whritenour is offline
Default Re: effects and aux sends
you pretty much answered all of your own questions there, lol
But i use compressors on each individual track that is being compressed rather than bussing to aux tracks and compressing all of them at once.
www.klarityrecordingstudios.com
Old 12-27-2005, 06:16 PM
Ditto. I use aux sends to aux tracks for all reverb and most delays. The delay exception is when I want to create a stereo widening effect on a mono track for a guitar part. That is the one time I will insert a mono in-stereo out delay plugin. Now a good use of setting an audio track output directly to an aux track would be for overall compression of a mix of several drum tracks or if you just had to have more than 5 plugins on a particular track(by routing it to an aux input, you could insert 5 more plugins in the chain).
Old 01-02-2006, 06:45 PM
bassbuddy bassbuddy is offline
Hi albee1952,
I wanted to bump this because I have a question on how you actually configure the aux/send relationship to get more than 5 plug-ins on a track using sends and an aux. track.Even though you explained it, I still can't grasp it. I was slightly confused on the last statement of your post on how exactly you can pull this off, but it is exactly what I have been trying to figure out. If you can help me, I will be very thankful.
Best,
Kenny
my webpage
Old 01-03-2006, 12:44 AM
Naagzh Naagzh is offline
Set up an audio track and two aux tracks.
Audio track's output = 1st aux track's input. 1st aux track's output = 2nd aux track's input. 2nd aux track's output = Analog 1-2. The signal flows directly from the audio track to the 1st aux track to the 2nd aux track and on to the mix buss.
Et voila, enough inserts for 15 plugs: 5 on audio track, 5 on 1st aux track, 5 on 2nd aux track.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 01-03-2006, 06:42 AM
Thanks bro...you da man.
Best,
Kenny
my webpage
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 12:10 PM
Effects Sends Help!!! Kubba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2005 04:45 PM
Aux and Sends question- Effects rightsidefalls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-27-2004 08:24 PM
outboard reverb and effects using the aux sends and inputs A Chadwick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-22-2002 01:42 PM
Sends, Aux and Effects pmh3r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2001 11:03 AM
