Old 09-22-2013, 09:18 PM
[email protected] mccoyrare@yahoo.com is offline
Default Do you have to have a 7200 rpm hard drive to run Pro Tools 10?
Old 09-22-2013, 09:34 PM
Craig F Craig F is offline
Default Re: Do you have to have a 7200 rpm hard drive to run Pro Tools 10?
If you do not want problems, it is highly recommend.
Thank you,
Craig
Old 09-22-2013, 09:46 PM
tmitchell tmitchell is offline
^ Haha, this is very true. What else would you be using? I will also add that SSDs and Flash HDs are also OK, obviously avoid any RAID configurations.
Old 09-22-2013, 10:52 PM
Glenjb Glenjb is offline
For your audio drive, yes you need a 7200 rpm with oxford chipset (and not a green or blue drive). Wd caviar black is a good one.
But your boot drive doesn't absolutely need to be 7200. For example my MacBook pro has the stock 5400 rpm drive and runs fine although it's on my list to swap it for an ssd or a 7200.
Old 09-22-2013, 10:56 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
Well there is 10 000 and 16 000 rpm beside flash and ssd drives
Manny.
Wave-T.com
Old 09-23-2013, 05:18 AM
If I had a buck for every PT issue that was solved by installing a dedicated 7200 RPM audio drive I'd be posting this from a beach in Hawaii.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 09-23-2013, 06:24 AM
8dB.co.uk 8dB.co.uk is offline
But from PT10 onwards, the disk cache helps loads.
I'm running large sessions in surround, audio. and HD video off a gigabit connected Synology NAS RAID drive. One initial "comment" from PT in workspace but no bandwidth issues.
I do have 16GB of RAM though, 8GB of which I give to PT.
I did initially try an iSCSI setup but it brought more limitations than benefits.
AWS.
Sent from my C6603 using Tapatalk 2
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 09-23-2013, 07:49 AM
That is HD only.
Thank you,
Craig
Old 09-23-2013, 07:52 AM
sw rec sw rec is online now
Sunburst....10 thumbs up!!! How many times HAVE we covered this??
Old 09-23-2013, 01:32 PM
Originally Posted by Craig F View Post
That is HD only.
And with the Now discontinued toolkits.
Is this 7200 rpm external hard drive ReynaldoPena Windows 1 11-20-2012 07:54 AM
2.5" 7200 hard drive ThaRhythm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-07-2010 11:54 AM
7200 rpm vs 10000 rpm hard drive akewldewd Storage Subsystems 2 09-26-2010 08:55 AM
FW Hard Drive Help? 7200 Fantom drive not working 72reissue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-10-2005 02:28 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
