Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-20-2019, 03:47 AM
jon.martins jon.martins is offline
Default Copy Clip Gain on multiple clips
Hello,
I'm using ProTools Field Recorder Track function to expand all field recorder tracks from the mixdowns used in film editing room.
However, while this function works well with almost all parameters from the Source Track (Volumes, edits, fades, automations...) it doesn't copy the clip gains on Expanded Tracks.
I'm trying to find a way to copy the entire Source Tracks clip gains to Expanded Tracks (so on multiple clips at the same time). I think i remember i had success previously by converting the source track Clip Gains to Volume, copy Volume automation to expanded track, then convert expanded track Volume automation back to Clip Gain.
However in the latests versions of ProTools, when converting (or coalescing) Clip Gains to Volume, it creates a automation point 1 sample before the end of each clip and creates a sort of fade until the next clip. The result is that when i convert back the Volume automation to Clip Gain on Expanded Track, i obtain a variable Clip Gain value on the entire clip (so Clip Gain Info disappears from view) and it's more annoying to edit clip gains on these clips (because of the break point on clip gain line 1 sample before end of clip).
Does anyone has a solution for this? Or another way to copy clip gain between two complete tracks with multiple clips.
PT10 Clip gain - multiple clips adjust at once? willco macOS 6 12-09-2018 08:39 AM
Copy clip gain on multiple clips? gdgross Pro Tools 11 11 09-18-2017 06:42 PM
copy clip gain bug? garnoil Pro Tools HDX & HD Native Systems (Mac) 2 12-18-2013 08:31 PM
Clip gain multiple clips workflow cjwalker Pro Tools 10 0 10-12-2012 02:53 AM
Clip Gain and Export Clips as files Farmer Dave macOS 2 03-18-2012 10:48 AM
