Old 07-05-2019, 03:47 PM
jdk11211 jdk11211 is offline
Default Workspace and Searchable Tags
I'm on PT 2018.10 trying to tag a large library of music with descriptions- key, orchestration, mood, etc. Tags created in 3rd party apps (Twisted Wave, Swinsian, Soundminer) are NOT visible in any of the columns in the Workspace window in Pro Tools. Any ideas how to get this to work?
Workspace "soundbase" window works to create tags in the files, but similarly, opening them in other apps, nothing visible. Ideally would like to be able to hand this library to a music super who may or may not have Pro Tools. any advice would be most appreciated!
Thanks,
JDK
Old 07-05-2019, 05:26 PM
BScout BScout is offline
Default Re: Workspace and Searchable Tags
In SoundMiner, did you write back to embed the tags into your library?
(I'm not sure if Pro Tools uses the iXML format or one of the others but SoundMiner, by default, does not write back into the file the tags. You have to expressly tell it to do it.)
Soundminer can write back to other tag formats but many of them are limited in scope so it can only write back what is offered
(I'm referring to SM pro; I know some tagging and batch tagging things aren't available in the other versions)
Personally I don't use the Pro Tools workspace soundbase at all so can't help you there. It's too slow/cumbersome compared to Soundminer for large collections.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Is there a way to delete tags that show up in the Assign Tags Pop-up Window? djbassvixen Pro Tools 12 1 02-23-2018 07:47 AM
Workspace Tags search box opens up constantly Inglesworth Pro Tools 12 8 08-04-2017 09:21 AM
USEFUL metadata editing of Workspace tags etc Tim R. Pro Tools 12 2 01-22-2017 09:34 AM
Fully Searchable AAX Database RussUK AAX Plug-ins 2 07-13-2012 12:54 PM
Fully Searchable Structure Database RussUK Virtual Instruments 0 01-09-2009 01:39 PM
