Old 07-02-2019, 03:41 AM
Rongoff Rongoff is offline
Default Playback Engine
Hello,
I have downloaded Avid Pro Tools driver but it doesn't show up in my playback engine.
Old 07-02-2019, 04:09 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: Playback Engine
With a total lack of information no one will be able to help you. How about system details such as OS, version of PT, what PT driver, etc etc.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB - 2 x Internal WD Blacks + MSATA card - Davinci Resolve 16.0b7 - Canon HF G40
Old 07-02-2019, 04:58 AM
I5 chip, 16 GB memory, Focusrite Scarlett 2i2 interface, Windows 10, Pro Tools HD, 500 GB SSD drive.
Old 07-12-2019, 06:14 AM
GuyPicks GuyPicks is offline
You need the Focusrite Scarlett 2i2 driver from focusrite.com
If you have a Gen2 then download that driver.
System 1---------------------System 2
MacPro 5,1---------------------------Windows 10
2-CPUs-------------------------------i7-CPU
OS X 10.14--------------------------Pro Tools 2019.5 HD
PreSonus 1824c --------------------HDX / 192 Analog
Fader Port---------------------------2-24" monitors
NI S61mkII--------------------------32GB Ram
64GB Ram---------------------------4 internal Drives
5-Glyph Rack Drives----------------Presonus 192 Mobile
2-24" Monitors----------------------Nektar Impact LX88+
Glyph Raid 4
Old 07-12-2019, 06:52 AM
junkgear's Avatar
junkgear junkgear is offline
After installing the latest Focusrite driver, you will be choosing the Focusrite selection from the Playback engine. Once that is selected, you will be able to use the interface. If for some reason PT isn't letting you choose it, hold down the N key while PT loads. This will bring up the PlayBack engine and let you choose your interface. If you don't see a Focusrite driver in the drop down, then you did not install the driver properly or your interface is not connected to your computer properly.
Will K
System Details
playback cuts out with plenty of CPU power left, have to change playback engine jmac146 Pro Tools 11 7 10-02-2016 11:34 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
Playback Engine keeps on forgetting my Duet USB Playback... plutopro Pro Tools 10 3 02-05-2013 12:42 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
