Old 05-23-2014, 02:07 AM
OliverH OliverH is offline
Default offline bounce from Send or Track outputs - track "freeze feature"
OK this is driving me nuts. I'm newish to Pro Tools and have always been used to having some sort of "freeze" feature in my DAW to commit processor-heavy tracks to audio to free up resources. I understand that there is no formal "freeze" function in PT HD 11, and that the best work around is to do an offline bounce of a specified bus or track output assigned to the track(s) you want to freeze.
That's all fine and makes perfect sense.
The manual (and many other articles online) says that if you simply "right-click" on the output path selector in the Mix window it will bring up a 'right-click' menu allowing you to select a bounce path (i.e. source being a pair of outputs, etc...). Once you do this the Bounce dialog opens with the output path you selected as the Bounce Source and you can then do a quick offline bounce of the tracks you need, re-import them into your session, make the old ones inactive, etc...
HERE'S THE PROBLEM
How in BLOODY HELL do you "right-click" on a Mac?? All these years I've always substituted control-click being as the Mac equivalent of right clicking. This does NOT work in this situation above though. I must be missing something because I cannot for the life of me get this dang "right-click" menu to open!!!
This offline stem bounce/freezing feature/whatever you wanna call it will be really useful... if I can get it to work and not have to Bounce to Disk the old fashioned way..... sheesh.
What am I missing???
Please help. :)
Mac Pro 3.5GHz 6-core (6.1, 2014 "trash can")
Sierra 10.12.6
32 GB RAM
Pro Tools HD 2018.12
HD Native Thunderbolt
HD I/O 16x16 Analog
Old 05-23-2014, 03:23 AM
joachim's Avatar
joachim joachim is offline
Default Re: offline bounce from Send or Track outputs - track "freeze feature"
File - Bounce to - Disk , choose Bus/Output , check Offline.
You do not use a mouse with a right-click ???
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 05-23-2014, 03:59 AM
JFreak's Avatar
JFreak JFreak is online now
Press control key before you click, or if you have a Trackpad, go to system preferences and enable two-finger click gesture, then you can just "right-click" by tapping with two fingers.
Janne
Old 05-23-2014, 04:08 AM
It's actually possible with a Magic Mouse to right click but the surface is finicky in doing so. You could do what I and others do and not use an Apple rodent - generic third party mice work just fine without any drivers.
Jack
QAPLA!
Old 05-23-2014, 05:34 AM
DetroitT's Avatar
DetroitT DetroitT is offline
System Prefs Mouse pane.
After an OS upgrade it may have reset the buttons.
Left click = primary
Right click change to secondary (Defaults to Primary)
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 05-23-2014, 10:12 AM
I do not. I am old-school and still rock a single clicker made by Apple from mid-2000's. Sounds like control-click will not work at least within the realm of PT11. Works for me in OS X and other applications, perhaps just not PT.
Would like to avoid buying new mouse if possible but will if I have to.
Sierra 10.12.6
32 GB RAM
HD I/O 16x16 Analog
Old 05-23-2014, 10:14 AM
Maybe that's what's required. Sounds like control-clicking simply won't work and I need to upgrade to a more "modern" Windows-type mouse system? Just was never a fan of the Apple multi-click mice. Generic sounds like a better option. Wish I didn't have to though.....
Sierra 10.12.6
32 GB RAM
HD I/O 16x16 Analog
Old 05-23-2014, 10:29 AM
Why don't you want to change? There's nothing that says you can't use a third party mouse. I was doing that way back on the toaster Mac se in the 80's. Like I said - get a generic 2 button mouse and be happy.
Jack
QAPLA!
Old 05-23-2014, 10:39 AM
No aversion to 3rd party mouse really. Just an expense I was trying to avoid. Thankfully it's a pretty small one. Thanks for the tip!
Sierra 10.12.6
32 GB RAM
HD I/O 16x16 Analog
Old 05-23-2014, 01:42 PM
No problem. In this oft expensive world we've chosen to muck around in a quality mouse is the least spendy thing and the one thing we use the most often.
Jack
QAPLA!
Why send tracks to hardware outputs instead of "Master" track/bus? gopher Getting Started 11 01-03-2014 12:12 PM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! italianguitar Eleven Rack 15 03-20-2012 01:57 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
Is Digidesign the only DAW software with the actual "bounce" feature? Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-09-2003 07:39 AM
