  #2191
Old 06-29-2018, 06:50 PM
Davidwilson Davidwilson is offline
Default Re: Control|24 and ProControl with Pro Tools 11?
Sounds promising - i think?
Sent from my SM-N950N using Tapatalk
  #2192
Old 06-29-2018, 09:57 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Jeezer View Post
..I had my eye on that for years but after demoing an ICON I just had to have that, but I'd not turn my nose up at a C24 for more basic faders/some plug in editing.
I swore I loved my Pro Control, until I got an Icon....best money i ever spent....i truly enjoy it.
But what’s even better is when I don’t even remember it’s there and am just working!!!!
Daniel
  #2193
Old 06-30-2018, 02:22 AM
Balanced Jack Balanced Jack is offline
Default Control|24 and ProControl with Pro Tools 11?
If other DAW’s currently support Eucon, could V-Control be updated in the future to “translate” the (much more in depth control of the) Eucon protocol to work with legacy controllers?
  #2194
Old 06-30-2018, 05:23 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
I have no information on that.
I do know that Paul Neyrinck still continues to fine-tune the HUI based version and tries to expand it where possible.
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.14.6 - Magma EB7 - PT HDX3 - PT Ultimate 2019.6 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x2) in a RAVEN CORE Station + 2 RAVEN CORE Station Sidecars - Almost all available AAX-DSP plug-ins
  #2195
Old 06-30-2018, 06:46 PM
Thanks for all the info above. Wasnt aware of all this progress re: control 24 being able to be used with PT 12 via V Control bundle.
After all this time waiting this is great news. Would love to hear peoples experience with this before i purchase though or can the free limited version give a taste of hiw this works .... demo????
  #2196
Old 07-05-2018, 08:51 PM
bcwiz's Avatar
bcwiz bcwiz is offline
I did some testing with Neyrinck's V-Control Pro using a Pro Control on PT12.5 Win7.
A bit of trouble getting it to go but turns out the Bonjour Service needs to be running... RTFM
Anyway working with a 24 fader Pro Control.
I haven't explored everything but so far faders are nice and responsive and the basics such as mutes, solo, sends A-E, banking, zoom, memory locations, etc. are working.
There are limitations mostly to do with the HUI protocol I guess. Pro Control/Control 24 Setup in Pro Tools
This is the initial release and more work is being done.
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
  #2197
Old 08-04-2018, 05:45 AM
Echo studios Echo studios is offline
About to make the final switch to Protools ultimate with procontrol with two faderpack sand edit pack.
How are the metering going on the Procontrol ? Same as before or ?
Do you run into Protools losing communication with Procontrol messages?
Thanks,
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack
MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB
OSX Sierra 10.12
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.sublimesoundstudios.com
  #2198
Old 08-10-2018, 11:40 AM
bcwiz's Avatar
Thanks,
The metering is a bit odd but I'm not used to all the metering choices in PT12. Pro Control meters are not great to begin with. I have hardware Dorrough meters monitoring LoRo as well as some good DSP software meters.
I had some communication issues (PT10) using a cheap 10/100 switch but after getting a gigabit switch no problems.
Brian Campbell
  #2199
Old 08-11-2018, 02:34 AM
Thanks,
I received your PM but when I try to reply I get the message your account does not allow receiving mails. So I will answer your questions in public.
The metering is not up to par with normal ProControl behaviour. V-Control Pro uses the HUI protocol and sadly HUI metering does not have the same high resolution as the ProControl protocol does. This means not all LED's on a ProControl are addressed by the HUI protocol. If I remember well the 3 most upper LED's (2 yellow LED's + the red overload LED) do not work. This also means that, if the ProControl Edit pack should become supported in the future, the high resolution metering will also never work as intended. Anyway I find this limitation in metering not a big problem as I never relied on ProControl metering anyway.
The connection with Pro Tools is rock solid. You can quit and re-open Pro Tools without V-Control Pro loosing connection with your ProControl. Or you can even enable and disable ProControl units in V-Control Pro when a Pro Tools session is open and running, even while recording if you would want to. But of course in real life you would not want to do such things. This is just some stuff I tried during beta-testing. EDIT: this is how it is on Apple hardware with various versions of the Mac OS. I have no experience with Windows.
Marc Schellekens
  #2200
Old 08-11-2018, 05:10 AM
OK. thanks for the precious infos here.
That’s what I wanted to hear!
I’m also running all the stuff on macOS too.
OSX Sierra 10.12
Dan Desilets
Vote for Control 24/ProControl drivers for Pro Tools 11 tekis ProControl, Control|24, Command|8 14 05-10-2015 05:14 AM
ProControl Vs Mc Control? surroundnoob ProControl, Control|24, Command|8 2 08-13-2011 04:05 PM
Should I get a Control 24 or ProControl??? A Spooner ICON & C|24 3 03-23-2005 10:59 PM
Should I get a ProControl or Control 24??? A Spooner ProControl, Control|24, Command|8 6 03-17-2005 10:48 AM
