Old 12-24-2013, 06:01 AM
mandal mandal is offline
Default Re: Pro Tools 11.0.2 HD - tempo decrease when i bounce to disk
I just tested the Bounce to QuickTime....
...added a video to the "piano C".
And the result:
A nice video....with the background music: "piano #G"
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 12-24-2013, 06:24 AM
Originally Posted by mjslakeridge View Post
After doing some quick mathematics, I don't think your issue is a 44.1 vs 48khz one. The frequency of any "G#" note to the next higher "C" note is 79.4 (rounded) percent of the higher note. The ratio of 44.1 to 48 is 91.875 percent. It would seem to me if it was a 44.1 to 48khz issue then the interval would be more like 1 and one half semitones, not the 4 semitones you are getting. Anyone?
Thanks mjslakeridge,
I did the same exercise in a session with sample rate 48kHz...
Recorded a "piano C" and bounced to both WAV and MP3.
When I play the bounced file in Windows Media Player - the recorded "piano C" is now almost a "piano B" (between A and B)
Avid OMNI PCIe
Old 12-24-2013, 06:30 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Originally Posted by mandal View Post
Hi
In the export menu I have:
- Selected Tracks as New AAF/OMF...
- Selected Tracks as New Session...
...can I create a MP3 here ?
No, to create an MP3 file, there is a "different" export process. Go to your edit window. Then go to the regions area on the right hand side and select the region corresponding to the audio you want to export. (I think PT calls regions-clips now). Right click and select "Export Regions as Files". On the next screen that pops up set your parameters, MP3, 44.1, stereo Interleaved, and choose a destination directory (I use desktop, so I can easily find the new file). Click on export, and the new file should be on your desktop, ready to test in Media Player, itunes. etc. Try exporting twice, once at 44.1 and once at 48 to see if that makes any difference in the pitch.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 12-24-2013, 07:51 AM
Hi
Yes, I did that...
In the CLIPS window....you can right click on the clip (region)...
...and "Export Clips as Files..."
Then I created a mp3 of my "piano C" into the "Audio Files" folder.
The same result....in Win Media it is a "piano #G".
I also double-clicked the "left" and "right" clip-file....the same result in Win Media Player...
Avid OMNI PCIe
Old 12-24-2013, 07:58 AM
Well, that would seem to rule out a problem with Bounce to Disk. Did you try exporting at both 44.1 and 48 to see if the pitch was the same? How about exporting as a WAV file or Windows Media Player file. Just trying to narrow down the possibilities.
  #16
Old 12-25-2013, 01:16 AM
Thanks a lot, mjslakeridge.
I did a test in a 48 kHz session - played the "piano C".
1) Bounced to disk
In Win Media Player...same result: The "piano C" played "almost a B"
2) Exported the clip as WAV and MP3 in 48 kHz
Please advice
I have also bounced to a QuickTime video....with same results.
Conclusion: The same physical file (a clip or region) - played inside Pro Tools - plays different - compare to Windows Media Player !
Session in 44,1 kHZ - a "piano C" inside Pro Tools will be a "piano #G" in Media Player
Session in 48 kHz - a "piano C" inside Pro Tools will be a "piano - between a A and B" in Media Player
I also noticed now that the Pro Tools tempo is wrong !!!!!
I set the Pro Tools tempo to 80 and tapped it to 100 in my Yamaha synth.
I set the Pro Tools tempo to 120 and tapped it to 150 in my Yamaha synth.
Hmmmm....can this be a OMNI hardware issue ?
http://duc.avid.com/showthread.php?t=285122&page=2
Best regards
Mandal
Avid OMNI PCIe
  #17
Old 12-25-2013, 06:55 AM
Hmmm, it could well be an Omni hardware issue. I am not familiar with that piece of equipment so what I suggest here may not be possible. Can you disconnect the Omni and manually insert some midi notes into a session using your computer mouse? Try playing a C note over and over. Then try the export clip or bounce to disk and see how it sounds in Media Player. If it is fine then that would seem to point to a hardware issue.
Another idea: Reconnect the Omni, and play some notes with your Yamaha. On the musical scale on the instrument (or midi) track, if you play a C note does it show up as a C on the scale?
Can the Omni be set as the Master Clock? If so try that (you will have to change some settings within PT). It sounds as though the tempo change is causing the drop in pitch. This is turning out to be a difficult issue. You may have to wait until after Christmas until some of the more experienced forum members are back on line to get some better advice. I am just throwing out guesses.
  #18
Old 12-27-2013, 04:07 AM
I returned the OMNI to my local dealer and hopefully they can verify if the hardware is OK or not...
I will keep you updated...
Avid OMNI PCIe
  #19
Old 01-22-2014, 02:58 AM
Puuuhhhhhhhhh......
Today....(20 days since I delivered my OMNI to my local dealer) ...they confirm hardware errors.
They will send me a new one...
Avid OMNI PCIe
  #20
Old 01-22-2014, 09:48 AM
mesaone mesaone is offline
Puuuhhhhhhhhh......
That's good news. An identified problem, however irritating, is better than a mysterious problem.
why does my tempo increase when i bounce to disk? Abel0470 Pro Tools 9 6 07-04-2011 04:59 PM
Bounce to disk cant bounce with MP3 (PRO TOOLS m-powerd)) DCstudio10 Pro Tools M-Powered (Win) 2 09-04-2009 09:27 PM
Bounce to disk error - pro tools won't let me bounce the file! HipHopHead Pro Tools M-Powered (Win) 1 05-14-2009 11:13 AM
"bounce to disk" ends up at a faster tempo blackie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-19-2005 10:44 AM
Levels Decrease after Bounce eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-29-2005 10:39 PM
