Old 11-18-2017, 05:13 AM
Stoney60 Stoney60 is offline
Default Loop Record doesn't record
Hi there,
I tried to "Loop-Record" some Drums. So I adjusted the bar-range (1-5), switched on the "Loop" in the Transfer-window, disabled Quick Punch, ticked "Automation in Record" and started.
What happened: PT started recording on the track, one time after the other.
Every time, the process started from "1", the recorded signals has been erased.
When I stopped recording, the track was blank. Only in the "Clips-Windows" there are the transmissions are listed.
So I checked Youtube on "How to do it right", but I obviously did not find a solution. Does anyone around here has an idea, what I could have forgot to activate/deactivate? So I think "Loop-Recording" should be pretty easy (as I know from other DAWs) and I believe, that I did something wrong I cannot figure out .
Thanks for any kind of help
Stoney
Old 11-18-2017, 05:48 AM
joachim's Avatar
joachim joachim is offline
Default Re: Loop Record doesn't record
In preferences, is "automatically create new playlists when loop-recording" checked ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-18-2017, 06:33 AM
Yes, it is enabled.
Old 11-18-2017, 06:44 AM
joachim's Avatar
Originally Posted by Stoney60 View Post
"Loop" in the Transfer-window, disabled Quick Punch, ...
Just to clarify : "loop-record" by right-clicking the record button ?
Or via Alt + L or Options-> Loop Record ?
Old 11-18-2017, 06:52 AM
Yes, I right-clicked on the record button, choose "Loop" and set it. As it is described in the manual.
I did it both ways – same result.
I also have checked Loop Playback. Don't know if that's right or not.
And … what I really do not understand: Why do the DAW overwrites the track any time, it jumps back
to one for the next process (e.g. four beats) but it counts every process and posts it in the clip section ^^.
Old 11-18-2017, 06:57 AM
joachim's Avatar
Do you see the takes with the track view set to "playlists" ? (Or just in the clip list ?)
Old 11-18-2017, 07:19 AM
Yes I see them
Old 11-19-2017, 02:00 AM
So here some update
#1 When I start to loop record (e.g.) PT records the signal (e.g. Kick Drum)
for the whole loop (e.g. bar 1-4).
#2 When the cursor jumps back to bar 1 and I try to record for e.g. the Snare Drum, the Kick is erased.
#3 If I stop the loop recording in the middle of the loop, the last recorded signals are still on the track, but all other loops before are erased.
#4 In the clips-window to the right the loops are counted properly (e.g. Inst 1-01, 1-02 etc.)
So to say I don't have any idea how I could fix that problem on my own.
Any advice?
Old 11-19-2017, 03:34 AM
joachim's Avatar
The Kick is erased, because its track is still record enabled, thus recording, but silence.
Can't you record kick and snare at the same time ?
You still need to say : when you change the track view from "waveform" to "playlist" ; can you see all the takes from top to bottom ?
Old 11-19-2017, 04:36 AM
Yeah, I can record kick and snare at the same time
pressing the keys alternately (hope thats the meaning of your question?)
I am going to try this tonight when I am back
thank you
Loop playback /record doesn't work. IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-18-2016 01:43 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
Master Record button doesn't record arm MIDI tracks? Borg ICON & C|24 1 10-29-2007 07:39 AM
Loop Record Doesn't give me pulldowns soundsurfr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-24-2006 12:09 PM
