Using one surface to control primary and secondary DAW simultaneously?
Hi all,
Apologies if this has been covered before but I couldn't find any info on the web. I'm trying to use a black-face Artist Mix to control Pyramix on Windows, but also control Rec/Stop transport of a secondary DAW on another machine running OSX via a switch. This secondary machine is controlled using Eucon Workstation MackieControl. I found on Avid's website stating that this is possible to do: http://avid.force.com/pkb/articles/e...415?popup=true But in true Avid fashion the explain-more link doesn't work... At the moment I've managed to get as far as the 'Enable External Workstations' function which lets me attach and detach the surface's control from one DAW to the other, which works great, but won't let me address both DAWs simultaneously. Any help would be greatly appreciated, I'm going nuts! |
Re: Using one surface to control primary and secondary DAW simultaneously?
Just found this thread:
http://duc.avid.com/showthread.php?t...e+workstations - so would I need to run the Workstation applet but NOT EuControl? And do I need to switch on 'Enable External Workstations' on the primary machine or the secondary? Or both?! I'll keep fiddling... |
The word simultaneously is misleading, you switch between them. Sounds like you have that working?
FYI — PT | Control + Artist Control simultaneously — soft key weirdness | thesoundguy77 | Artist Series | 4 | 11-11-2016 09:10 AM |
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Control 24, Axiom Pro and Midi I/O simultaneously ? | Lizardpoint | ICON & C|24 | 5 | 06-16-2009 03:43 PM |
comp speakers as secondary [or primary] monitors | arcarsenal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-25-2003 03:21 PM |
