Old 12-08-2013, 02:40 AM
[email protected] kirstencrom@gmail.com is offline
Default Arturia Spark reduces other Track Volumes when not muted.
I am running Pro Tools 10 on Mac OSX 10.7.5.
I have Arturia Spark as a Plug In on an Instrument Track.
I noticed that when I mute the Instrument Track containing spark, my other Pro Tools tracks are at normal volume. (I am just using Pro Tools virtual instruments on all of the other tracks). However, as soon as I unmute the Spark track, all of the other track's volume is reduced. Then I mute the Spark and track and the volume comes up again.
Then I noticed that when I pull the fader down on the spark instrument track, the volume of all the Pro Tools tracks rises. When I push the instrument track up, all of the tracks decrease in volume.
My mind is blown.
Is this a Pro Tools Issue or Spark?
Old 12-08-2013, 03:41 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Arturia Spark reduces other Track Volumes when not muted.
My guess is that you have a limiter on the master and your Arturia is on a higher level than the other tracks. When you hit the limiter with Spark gain reduction happens to itself and (of course) to all other tracks also, but as already said, because of the high level of Spark, on tracks with less level you will hear the gain reduction better.
Check your levels!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 12-14-2013, 01:31 AM
This was the solution, just taking the limiter off of the master. Should I try to bring all the other levels up to match Arturia? Or bring Arturia down to match all of the other levels?
Old 12-14-2013, 01:43 AM
clausiii's Avatar
I'd lower Arturia's volume...
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 12-16-2013, 03:37 AM
Okay the problem was solved in Pro Tools...now the same thing is happening within Arturia. I made a group of Toms, then wanted to add a Bass Drum. When solo the bass drum in the sequencer, it sounds great. But I un solo it, and now I can barely hear it. And no matter how I try to compress it, it is just not the same.
I feel like when people make beats, one drum sound effecting another drum sounds volume isn't usually a problem. The individual drum sounds stay the same, and a bass drum is not dramatically turned down when other sound are playing. Am I right?
HTML code is On
Arturia Spark and Pro Tools 9.0.3 papacriss macOS 4 10-19-2017 03:17 PM
ARTURIA SPARK WORKING in PT 11 cstars AAX Plug-ins 0 08-02-2013 10:37 AM
Arturia Spark Problems In Pro Tools 9 Help ! 15th SINE Virtual Instruments 1 10-29-2012 03:13 PM
I CANT PUNCH WITH THE DARN TRACK MUTED!!!! (MBOX) Swann 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-22-2006 07:35 PM
2 Track Editor aside from Peak and Spark XL Imagine Pro Tools TDM Systems (Mac) 10 02-16-2005 12:49 PM
