Old 12-29-2010, 10:28 AM
active active is offline
Default HD9 with Apogee Symphony
Anyone else having problems with the new HD9 and the Apogee Symphony IO? If i open an older session and change the buffer rate, i seem to lose all audio output. when i change it back, i still get no output. sometimes restarting the device works, sometimes just HD, sometimes everything.
Old 12-30-2010, 07:52 PM
MilesWalker MilesWalker is offline
Default Re: HD9 with Apogee Symphony
I have that set up, and am going back to older sessions and not having that problem. I'm usually using 256 as my buffer rate, and that hasnt' been an issue. However, I find that if an older session was using external word clock as the source, sometimes it will get that bug. Then if I just set it back to Internal from Sync Window and cycles through the clock, it will start playing. Does any of these sessions you are having problems with audio playback have an external clock setting?
Old 03-29-2011, 09:02 AM
i think we got it all ironed out. something wasn't talking to something properly and after a bunch of updates and reseating connections it all seems to be fine now. just the dreaded i/o craziness!
Apogee Symphony, symphony 64, motu 128, 3u rack case chrisgil Buy & Sell 1 02-18-2013 10:48 AM
hd native + apogee symphony? ericlees Pro Tools HDX & HD Native Systems (Mac) 12 01-23-2013 03:38 PM
Apogee Symphony and PT9 forjam Pro Tools 9 10 02-01-2011 01:52 PM
Apogee Symphony 64 and Pro Tools 9 forjam Pro Tools 9 3 11-07-2010 06:11 PM
HD & Apogee & Symphony bigfatjim Pro Tools TDM Systems (Mac) 0 03-06-2007 05:36 AM
