Hard Drive Size and Partitioning
Hey all! New to the boards and pro-tools here. I'm sure this has been adressed but I couldnt find a post completely on topic so here goes again.
What size hard drive is optimal for my audio drive? Is there an advantage to a 40gig vs 120 vs 200? I've heard that the smaller drives are faster but I'm not sure thats still a significant consideration. Is the advantage to one or the other theoretical or will it be noticable? (talking strictly IDE here). What about partition size? Does that make a difference and what is a safe size for 32 tracks with about 10 mins or so per song? Thanks! |
Re: Hard Drive Size and Partitioning
1) Smaller drives defragment faster. 2) When a smaller drive crashes you lose less data! If you do a lot of audio editing that results in small file sizes and/or lots of fade files you will need to defrag once in a while for optimum performance. You'll notice a big difference in defrag times between a 40GB drive and a 200GB drive! Drives eventually do fail. It's a fact of life. You'll lose a lot less data if you have 200GB of data spread across 5, 40GB drives instead of one 200GB drive. If you only have a single 200GB drive and it has a physical head crash, you might possibly lose everything on it. If you spread your risk across several physical drives you lose less if one of them fails. I don't have much of a suggestion for drive sizes. I always have bought 40GB drives. They are available at prices I can afford and justify, and I can easily fit 2 or 3 albums or more material on there including final mix bounces and mastering files. You might need more space if you keep everything you ever record and you do a lot of takes. Good luck! Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
I just installed the WD 36Gig SATA drive that spins at 10K, works like a charm and the disk and SATA controller card was 200 bucks from www.newegg.com.
Rob
www.carvelstudios.com |
Sounds good, but it's about 3 times as much money as a 40G 7200rpm EIDE drive. I don't think the performance gain justifies the cost.
Quad 2.5 G5, 4.5G RAM |
I really need to conduct more tests to push the disk... but for the most part you're probably right.
by the way, for the record, i totally agree with quickdraw...
i love my apple iPhone! |
me too, I like 40-60G audio drives, as many as it takes.
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Rob
Partitioning a Hard drive | Marty McFly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-05-2006 10:16 PM |
PARTITIONING YOUR HARD DRIVE IN OSX? | Dan M. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-13-2004 02:15 PM |
partitioning hard drive | Prophetico | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-21-2002 06:09 AM |
Hard Drive Partitioning | mrwong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-13-2000 02:28 PM |
Hard drive partitioning | bonneybear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-11-2000 01:06 PM |
