Old 01-09-2008, 11:14 AM
eddiewes eddiewes is offline
Default DAE error 6006 on Delta 1010LT
Is there anyone knowing why I get error 6006 on my PT MP with M-Audio Delta 1010LT card with the latest M-Audio drivers for this card. I don't even have any fire wire devices?
Old 01-11-2008, 07:53 PM
wtxguru wtxguru is offline
Default Re: DAE error 6006 on Delta 1010LT
I had the same problem. Using M-powered 7.3.1cs5 with the latest Delta drivers. I had to reload the previous drivers, to get Pro Tools to start up again.
Old 01-17-2008, 11:19 PM
My problem was that I have two Delta1010LT cards in my PC and the new M-Audio driver can't handle multiple cards. I have reported this to M-Audio and I hope they will find a solution to this a.s.a.p.
So, by disabling the second card in Windows "system properties" I get it all to work.This works for both Win XP and Win Vista.
Regards
Old 02-17-2008, 01:02 PM
Problems solved
By using M-Audio driver xxxxx.xxxx. 057 it all workes together
change of sample rate on delta 1010lt causes delayed write error woodpigeonblue Storage Subsystems 0 01-08-2010 04:29 AM
Looking to move to PC so I can use a Delta 1010LT jj5000 Pro Tools M-Powered (Win) 2 12-09-2009 06:42 AM
PT and Delta 1010LT ziggy1621 Pro Tools M-Powered (Win) 0 01-03-2008 06:26 PM
Delta 1010LT and 10.4.6 jbmelby Pro Tools M-Powered (Mac) 0 04-23-2006 09:33 AM
Delta 1010LT Hardware Help NoGreatMan Pro Tools M-Powered (Win) 2 12-01-2005 03:07 PM
