Recording NI Kore Electronic Experience
Hi all, here is the situation. I create an instrument track with Kore Player as the plug-in, select a patch, all is good. Enable record on the track and the transport and click play. I hear one click from the click track and it stops recording. Delete track, setup another one using a different plug-in (IK Sonik-Synth2) hit record and it works. I've looked through the documentation and I can find nothing that would seem to explain this behavior. Any suggestions are welcome, thanks.
Re: Recording NI Kore Electronic Experience
To save any other poor soul the hassle if you own this product...
KORE 2/KORE PLAYER causes the transport to freeze in Pro Tools Q: When I insert KORE 2 (or the KORE PLAYER) in Pro Tools 7.4 on Windows, I can no longer play back or record audio. The transport does not work, and when I press play or record, nothing happens. What can I do? A: This issue is due to a bug between KORE 2/KORE PLAYER and Pro Tools 7.4. This will be fixed in a future release. However, you can work around this problem by going to Setup>Playback Engine in Pro Tools and UNchecking the 'ignore errors' option. |
Recording an electronic drum kit? | Tom Case | Pro Tools 10 | 9 | 03-22-2012 06:58 AM |
Noobie need help - Recording with Kore Player | JeanDit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-15-2009 04:17 PM |
Kore and Recording automation not working | joji | Pro Tools TDM Systems (Mac) | 4 | 01-25-2009 09:59 AM |
latency when recording from electronic kit | phentalmyst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-25-2006 12:10 PM |
Anyone using electronic drums for recording? | 8mmOverdose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 04-27-2002 06:30 AM |
