Old 10-31-2011, 07:05 PM
jhorsley jhorsley is offline
Default Clicking Midi I/O causes 5-10 second spinning beach ball
If we click on on the midi I/O we get the spinning beach ball for about 5-10 seconds, then it clams down and we can change the midi channel. What is causing this delay? It is very detrimental to our workflow.
Our sessions have about 100 midi tracks, 40 Aux tracks, and 2 instances of Vienna Ensemble Pro. (Samples hosted on another computer)
Pro Tools 9.0.5
Vienna Ensemble Pro 4.1.8861
Mac Pro
OSX 10.6.8
2 x 2.8 GHz Quad-Core Intel Xeon
16 GB 667 Mhz DDR2 RAM
Digi 002
Joachim Horsley
www.LittleHorseMusic.com
Old 10-31-2011, 08:45 PM
@ndy's Avatar
@ndy @ndy is offline
Default Re: Clicking Midi I/O causes 5-10 second spinning beach ball
Poorly written drivers!
Have you tried ditching your AMS prefs? If not, ditch this one as well -->"com.apple.MIDI.xxxx.plist '(in the By Host folder)
That might help. Reinstalling the driver or updating the firmware couldn't hurt as well.
Good luck
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 11-02-2011, 05:01 PM
These are all good ideas, but unfortunately the problem persists. Any other ideas?
Joachim Horsley
Old 11-02-2011, 05:14 PM
@ndy's Avatar
Have you tried another USB cable and different USB port? You could even reset your PRAM before trying out the new USB port. I don't know if any of that will help, but it's easy to try. Did you have this problem with 9.0.3 or is this new with 9.0.5?
Old 11-02-2011, 05:54 PM
RTFM RTFM is offline
This is a known issue in 9.0.5. The only solution is to revert to an earlier version or wait for an update that fixes it...
Old 11-02-2011, 05:59 PM
@ndy's Avatar
There is an update that fixes it... and it costs $299!
Old 11-28-2011, 07:32 PM
pkm pkm is offline
Same problem here. How did this update get out of beta?
Old 11-28-2011, 10:23 PM
dterry dterry is offline
I rather doubt 10 would fix this since it seems some 9.0.5 issues carried over, but it might.
There are serious midi delay issues in 10 on Win7 9 (also in 9.0.5). Avid knows about it and has listed the bug.
I have no idea if it's related to the midi I/O delay on the Mac side as I'm not seeing that here, but there are other serious delays with large midi track counts.
For the OP: I would drop back to 9.0.3 or earlier and see if that solves it.
Old 11-30-2011, 01:12 PM
YYR123's Avatar
YYR123 YYR123 is offline
Didn't the 9.0.6 update just fix midi track output assignments?
I think i read that?????
Daniel
Old 12-01-2011, 04:35 AM
paulreed paulreed is offline
try stepping back to 9.0.3
[IMG] code is Off
Spinning Beach Ball.... Help StevieDebe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-07-2011 06:40 AM
Spinning Beach ball Before Playback. Help! winstonjack Pro Tools TDM Systems (Mac) 4 06-22-2011 05:38 AM
Spinning Beach Ball with Pro Tools 9 Moviesound macOS 4 03-21-2011 11:45 AM
Spinning beach ball after scrub? D'Animation Pro Tools TDM Systems (Mac) 3 05-04-2010 01:48 AM
spinning beach ball when doing almost anything... Muzoid Pro Tools TDM Systems (Mac) 4 01-01-2006 08:57 AM
