Old 07-08-2017, 03:08 AM
hotmits hotmits is offline
Default PT Not Seeing WAVES Plugins.
Morning All,
I've got a bit of a weird issue in as much as Pro Tools (12.8) is not seeing any of my Waves plug-ins. I've un-installed and re-installed them via Waves Central, 're-scanned' for all plug-ins (on PT startup) and followed all the suggested fixes from Waves themselves (I'm waiting on an update from them in response to an email I sent them last night).
All the plug-ins are in the correct folders and I can see PT loading the Waveshells as it starts up.
If it helps, then this is the spec of the Mac:-
- Mac OS 10.12.5
- Processor 2 x 3.46 GHz 6 core Intel Zeon
- Memory 64Gb 1333 MHz DDR3
- 3 x HDX I/O's plus HD Sync
- Pro Tools Version 12.8.0.864 (although the problem did occur with 12.7 as well.
I'm not sure if it's relevant, but the problem occurred after I'd bought and installed a new plug-in (the H-Reverb Hybrid Reverb from Waves). The other thing that might be helpful to know is that when I select to display the plug-ins by Category and Manufacturer, WAVES does not appear in the list !!
If any of you have experienced this issue and have the magic solution, I'd really appreciate some help and words of wisdom. If you need any more info, then don't hesitate to get in touch.
I've attached a screen grab of the relevant Waves folders in case it helps.
My warmest regards to you all.
Alex
Old 07-08-2017, 08:45 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: PT Not Seeing WAVES Plugins.
Waves show up here just fine. Why wouldn't you contact Waves Support?
Janne
Old 07-08-2017, 09:06 AM
hotmits:
Are you letting the Waves installer put the plugins where it wants to?
Here's something to try just to see if the Waves stuff is installed semi-correctly:
grab the demo of BlueCat Patchwork - it hosts au and vast plugins
insert the Patchwork demo on a PT aux track
in one of the slots in Patchwork insert a Waves plugin (either au or vst)
if the selected Waves plugin shows up then at least the major part of Waves is good
A thought - is the current Waveshell in the library/application support/Avid/audio/used plugins?
Jack
QAPLA!
Old 07-08-2017, 09:33 AM
JFreak's Avatar
Yep, the root cause may very well be with the WavesHell...
Janne
Old 07-08-2017, 04:16 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Two questions: Is there a WaveShell in your Plugins folder? Also, does the waves spinning w animation occur during Pro Tools start up?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 07-08-2017, 05:52 PM
krsongs krsongs is offline
I have the SAME problem this week.
PT 11.3.1/OSX 10.8.5/iMac
Pro Tools AND my vast Waves plugins all work beautifully, except the Kramer Master Tape and NLS Summer I downloaded this week. It is in the Waves folder with all my other Waves plugs.
To answer your question: Yes, the current Waveshell IS sitting in the library/application support/Avid/audio/used plugins AND it is also sitting in UNUSED with the colored Waveshell icon. (See pic.)
Is this the problem?
Does it too need to be moved to "Plugins?"
Sorry don't mean to hijack!!
Kiki
File Type: jpg Screen Shot 2017-07-08 at 5.47.46 PM.jpg (42.4 KB, 0 views)
Old 07-08-2017, 08:48 PM
Top Jimmy's Avatar
How come nobody has tried the usual?
Uninstall and reinstall the waves plugins?
Trash Pro Tools' prefs?
Hold shift while starting PT and fiddle with the Waveshell settings when the popup comes up?
One thing I would suspect is installing 1 or a couple new plugins could result in getting waveshell and plugin version mismatches. I would uninstall waves, trash any lingering waveshells and other waves files, then reinstall them from the ground up.
James Cadwallader
Old 07-09-2017, 03:52 AM
Kiki
Sounds like your system is getting confused; is the one in the unused folder the same version as the one in the used folder? You only need one so I'd remove totally the one in the unused folder but save it off somewhere safe but not on the machine.
The op already tried most of those ideas and nothing seemed to have worked.
Jack
QAPLA!
Old 07-09-2017, 09:42 AM
elicious elicious is offline
trash your waves prefs.
quit PT.
In finder, click on the Go menu, hold down the opt key and click on library.
go to Preferences > Avid > Pro Tools.
Locate the InstalledAAXPlugins file and drag it to your desktop.
Launch PT, create a fresh session, add a track.
If you get a prompt to Locate the Waves plugins folder, point it to Sys HD > Applications > Waves > Plug-Ins V9.
If it works, you can delete InstalledAAXPLugins from your desktop.
hth,
e
ihatetyping
Old 07-09-2017, 01:13 PM
quit PT.
I have no such files AVID,WAVES, or DIGIDESIGN folders in Preferences (check out first image.)
I DO see a Waves folder in DIGIDESIGN/PLUG INS folder. Should I drag this to trash? (Check out second image.)
I wonder if I drag all Waveshells to trash? Someone called it "WavesHell" and I completely understand now!
Thank you!
Kiki
File Type: jpg Screen Shot 2017-07-09 at 12.59.37 PM.jpg (85.1 KB, 0 views)
File Type: png Screen Shot 2017-07-09 at 1.04.27 PM.png (31.2 KB, 0 views)
HTML code is On
FS: Waves Kramer Master Tape and other Waves plugins MatthieuH Buy & Sell 0 05-16-2016 08:57 AM
Waves Plugins lahmur Pro Tools 12 1 01-28-2016 12:20 PM
FS - Waves plugins, AVID plugins Rosco1969 Buy & Sell 12 03-11-2014 11:56 AM
Waves Plugins FS $65 crandallwarren Buy & Sell 1 02-08-2014 08:40 AM
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 06:20 AM
