Old 07-18-2011, 06:11 PM
Charvelman Charvelman is offline
Default Eleven Rack control window
The guitar window inside Pro Tools isn't displaying any of the graphical icons correctly....no foot pedals, amp cabs, etc. Everything else seems to be where it should be. Anyone else have this problem...? I just installed 9.0.3, and my Eleven has the latest firmware version 1.0.3......thx
Old 07-19-2011, 04:54 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack control window
so, WAS is working correctly BEFORE upgrading to 9.0.3? What did you upgrade from - 9.0.2? 8.0.5 LE?
Also Firmware 2.0.1 is the latest, not 1.0.3. Firmware 2.0.1 is a paid upgrade ($99 US) that adds more amps and effects.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-19-2011, 06:25 PM
Thx for responding.....what happened was, I had to reinstall Pro Tools....first from LE 8 that came with 11 rack, and then adding on Crossgrade 9. I never had a problem with the display before, is the thing, when I used it prior to the full reinstall.....Only now....and it also worked fine with the 1.0.3 firmware in the past......I'm on the fence about trying the paid upgrade. Not sure if that would fix the display issues, but I'd get new amps, I guess heh heh.
Old 07-20-2011, 10:02 AM
Benoni's Avatar
so you did an upgrade of PT8 LE? Have you tired downloading the full PT9.0.x installer, and install the full version instead of using the update?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 07-20-2011, 05:33 PM
I re-installed the original LE 8 program that came with Eleven Rack.....again, in the past, never had a problem with the control window with that program....then, I re-installed the Crossgrade 9 disc which I purchased months ago. Again, I used the crossgrade 9 program in the past with zero problems. The problem with the control window only started about a week ago, when I had to reinstall both programs because of computer issues.....the only difference this time, is that I also added on the 9.0.3 update....I wasn't using that before.
Old 07-21-2011, 07:07 AM
brianiac5150 brianiac5150 is offline
Re-install the Eleven Rack (Expansion Pack if you have it) software and it should fix it. I had the same thing happen on both a PC and Mac platform and this fixed it for me. Hope it works for you, too.
THoM Facebook
Old 07-21-2011, 08:57 AM
bassmanjazz bassmanjazz is offline
I installed a protools update and lost my gui updates in pt that reflected the changes in the 11rxp. I ran the xp updated to the point where it told me I was already using the codes (this is normal if u installed it already) and got the gui back. I am guessing a similar action will fix it up for ye!
Old 07-21-2011, 01:14 PM
Benoni's Avatar
from his post, he is using Firmware 1.0.3 and does not have the ERXP, so if he is correct, then there is another problem.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
No Eleven Rack Control Window With Pro Tools 11 turbolx5oh Eleven Rack 15 12-08-2014 03:28 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven Rack control window? microstudio Eleven Rack 6 02-25-2011 01:04 AM
Where is the eleven rack control window? Hotcrazyfruit Eleven Rack 32 10-22-2010 03:21 PM
