Old 07-22-2010, 02:02 AM
Moviesound Moviesound is offline
Default Why use 'Punch Auto Preview' and not just 'Write Auto to Selection?
Can someone tell me why you need to ever use 'Punch Automation Preview'. I always audition in Preview mode then when ready just hit 'Write Automation to Selection'.
Am I missing something? Should I be hitting 'Punch Auto Preview' as well.
I do have alot of automation not writing from my Dcommand?????
Old 08-03-2010, 07:27 AM
Simon Sherbourne Simon Sherbourne is offline
Default Re: Why use 'Punch Auto Preview' and not just 'Write Auto to Selection?
You don't need to use Punch before pressing Write To All. Either way, anything you changed will be written within the current time selection. You'd use Punch if you wanted to start writing your Previewed mix values in real time.
Old 08-03-2010, 08:05 AM
cneal92's Avatar
cneal92 cneal92 is offline
Punch will only write automation points on the parameters that you have touched/isolated in the selection. Where Write to All will write automation to all parameters that are write enabled in the selection, whether you touched them or not.
So using Write to All is good when you want to 'lock' down a section and prevent inadvertent changes that might easily occur to that section when working on another section.
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 08-03-2010, 08:16 AM
You're thinking of Automation>Write To All Enabled. That writes to everything (within the Edit Selection)
Write to All writes isolated parameters within a time range (Punch doesn't influence this)
Old 08-03-2010, 08:53 AM
Henchman Henchman is offline
I use it quite a bit actually, although I've been using write preview to selection a bit more now.
I'll use preview, loop a section, setup my changes, then rollback, and hit punch when I get to where I want to have the change. Then if needed automatch out.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 08-03-2010, 09:16 AM
JKD99 JKD99 is offline
Which method would one use if you wanted to write new auto for one plug-in on a track (say, the Cedar), but not disturb the others (EQ and Dynamics) without manually "Safeing" the ones you want to protect?
Thanks!
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 08-03-2010, 12:13 PM
Brandonx1 Brandonx1 is offline
punch preview
Old 08-03-2010, 12:43 PM
Stig Eliassen's Avatar
Latch automation.
Old 08-03-2010, 01:22 PM
SBP SBP is offline
Thanks!
Hi -I'd suggest the following. -working in latch automation with latch prime enabled.
1 -Go into preview mode.
play the scene and get the settings you want. (nothing is actually written in preview. when you are happy.
2-Select the range on the timeline you want those settings to be writen over.
3-hit 'punch preview' -now you can play through the scene writing the settings (and bumping and wiggling as you go) or you can hit 'all' and write the currently active automation settings to the selection made before you hit play.
Hope that helps
All the best
Bruno
Old 08-03-2010, 01:25 PM
Thanks everyone, I'll give those methods a try!
cheers,
Joe
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
HTML code is On
What does 'Punch Auto Preview' do? Moviesound Pro Tools TDM Systems (Mac) 4 07-22-2010 04:52 PM
Auto Write To... subwoof ICON & C|24 0 05-20-2009 01:11 PM
Auto write "All" 7.4 SBP ICON & C|24 7 02-21-2008 12:20 AM
Auto Write to End/Start/All 7k ProControl, Control|24, Command|8 6 05-12-2006 09:25 PM
Auto write didn't work. Please help. cityuapa Pro Tools TDM Systems (Mac) 2 01-04-2005 10:54 AM
