Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-16-2015, 05:53 PM
rogerfiets rogerfiets is offline
Default Focusrite Scarlet 6i6 issues (PC)
I recently purchased a Focusrite Scarlett 6i6 to use with my portable Pro Tools rig. Installing it was no problem, and it ran right of the box. Where I’m running into a problem is when I switch sessions at different sample rates. I have some older sessions that were created at 48k, and I want to keep them that way. Initially, I thought I would change the sample rate in the Mix Control panel and re-launch Pro Tools. As soon as I push play, I get an error message in Pro Tools saying - “Pro Tools could not initialize the Focusrite USB 2.0 Audio Driver. Please make sure that the device has been configured correctly.” The software hangs, and I have to shut it down by way of the Task Manager. I’ve looked on this forum, but I cannot find a solution. I even tried to download and install the version 3.1 driver. It wouldn’t even recognize the hardware. I consider myself to be pretty computer literate, so if anyone has a suggestion, feel free to get as technical as you like. Please see my specs below.
Computer - Model : HP p6-2123 103C_53316J G=D
Processor : Intel(R) Pentium(R) CPU G630 @ 2.70GHz (2C 2.7GHz, 2.7GHz IMC, 2x 256kB L2, 3MB L3)
Windows 7 Home Premium 64bit (Service pack1)
Total Memory : 8GB DIMM DDR3
Pro Tools M-Powered 11.3
Mackie Onyx 1640i (M-Audio
Old 03-17-2015, 07:30 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Focusrite Scarlet 6i6 issues (PC)
These problems seem to vary from manufacturer to manufacturer. Heres' a good relevant thread (although it doesn't have much for suggestions) http://duc.avid.com/showthread.php?t=360228
While not an option if you work with other peoples sessions, I always use the same settings in all my sessions to limit these problems.
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 03-17-2015, 07:50 AM
Hi Joel,
Thanks for posting the thread. Yes, it was helpful. It is very interesting that other people are having the same issue with the Focusrite interface. I also have a Mackie Onyx 1640i (M-Audio protocol) that I do not have this problem with. What I'm doing now, is saving a copy of my 48k sessions to 44.1k. This seems to solve the problem, but I sure hope Focusrite develops a drive that works correctly with Pro Tools.
Roger
Focusrite Scarlet 18i20 tchipman Third Party Interfaces 43 06-03-2015 09:05 PM
Pro Tools 11 and Scarlet 2i4 SomebodyHelp Third Party Interfaces 2 04-19-2014 11:09 PM
Mbox Micro with PT 8 LE + Focusrite Scarlet 2i2 elmodagansta Windows 2 02-08-2013 02:57 AM
scarlet 8i6 davidlustrup Windows 2 12-22-2011 12:56 AM
transfuser with protools 9 and focusrite scarlet 8i/6 zela8 Virtual Instruments 0 10-16-2011 10:27 PM
