Old 02-17-2015, 10:42 AM
Shambhalawar Shambhalawar is offline
Default Pro tools LE 8.0 "Required software extensions are missing."
About 6 years ago I bought pro tools 8 and it ran great on my mac book pro, which I bought new about 7 years ago. I stopped playing music and using protools for roughly 5 years, just yesterday I tried to run pro tools and I get this message. I have never had issues with PT on this laptop and the only difference I can think of since it ran correctly, is the OSX changes and updates, and updates to how AVID runs their products and licensing.
The MBOX 2 does not light up at any point (I can't remember if it required PT to be running before the lights powered on).
I get the message,
"Click the "OK" button, and you will be transferred to the PACE web site where an installer can be downloaded."
When I get redirected to the PACE page is says the things have moved and the page is no longer there. I have tried to research this on my own and I am still confused.
1) Is this problem occurring because all versions of PT (including 8) now require "ilok"?
2) Does my version of OSX 10.9.5 support PT 8 and MBOX 2 (this is my hardware)?
I tried uninstall/reinstall and the same issue occurs.
Also tried upgrading to PT version 8.0.5, same issue occurs.
Pro tools LE 8.0
7 year old mac book pro
OSX 10.9.5
4 GB ram 1067 MHz DDR3
MBOX 2
Any help is greatly appreciated!
Old 02-18-2015, 04:38 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: Pro tools LE 8.0 "Required software extensions are missing."
Answers -
1) No. PT 8 and below used the Digi interface as the dongle. In your case, that's the MBox2. Your problem is your OS / PT compatibility.
2) No. The last OSX version to be supported with the last PT 8 version was OSX 10.6.8 with PT LE 8.0.5.
You will need to either roll your OS back, or buy a PT 10/11 license and DON'T install PT 10 until you've researched PT 10 on OSX 10.9.5. The uninstaller for PT 10 was broken in Mavericks, so if you're hip enough to follow the manual uninstall protocol (if you need to uninstall PT 10), then go ahead. By the way, if you upgrade PT, you'll need an iLok2 for $50.
Old 02-08-2016, 04:05 PM
guitartwins02 guitartwins02 is offline
Hello everybody
After a long time without using the ProTools, I decided to use it again, but every time I try to start the program I get the same:
It also happens with Garageband.
Something must be wrong with my old OS X
I hope you can help me.
Thanks in advance.
Best greetings!!
Hi
Thanks for the info, and your welcome. I hope to find answers here. Cheers. Ernesto
PT9: Required software extensions are missing bnjmn84 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-28-2011 08:51 AM
Required software extensions are missing??? bootyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-26-2010 06:13 PM
Can't open PT on new Imac -- "Required software extensions are missing" jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-21-2009 07:27 AM
"Required Software Extensions are Missing" resway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-03-2008 07:18 PM
"required software extensions are missing" frankreverbo Pro Tools TDM Systems (Mac) 8 01-24-2008 10:51 AM
