Old 11-04-2000, 11:15 PM
MichaelK MichaelK is offline
Default Re: Transfering note data from a sequencer to the sequencer of the digi 001 sequencer?
That was a darned good question!! I have an XP-80 and I looked for a way to do it, but I don't see how. It doesn't seem to be able to send song data via MIDI; it can only save to disk.
I hate to say it, but I think only feasable solution is to just get an external floppy drive so you can read properly from one machine to the other. Or find someone with both a Zip and floppy drive who will let you use their machine to transfer one to the other.
- Michael
-- Michael
PT Ultimate Native 2021.10
Mac Pro 7,1 16-core, 288G RAM
OS 11.6.1 Big Sur
Old 11-04-2000, 11:42 PM
AnalogTree AnalogTree is offline
Hey, great controllers huh! The studio I'm using has one too, and I was thinking about doing the same thing, also want to use the arpeggiator in sync w/ PTLE but haven't figured it out yet. I think that transfering sequencer data over midi must be possible. Well, it should, dunno. I might try and check this one out. Would be cool to whip up a basic sequence in Roland and then pass over to graphical editing in PTLE. This is the idea, right? I like it. Although, I'm digging in to the PT sequencer more and more every day (just started to use it a couple days ago,) and hope to use it instead of the Roland.
-AT
Beethoven can write music, thank God, but he can do nothing else on earth.~ Ludwig Van Beethoven
Old 11-04-2000, 11:48 PM
...Hmmm...you know, before I bail, this is a Jimmy Rig of an idea, but it will definitely work...Send clock from your Roland to sync w/ PTLE as slave and then PLAY your sequence into the PT sequencer as it records. I used to do this with a couple sequencers, and even if PT can't sync (which seems unlikely) then just hit start at the same time and quantize. Oh well, a little lame but doable. :-0
-AT
Old 11-05-2000, 12:29 AM
ABrown ABrown is offline
Default Transfering note data from a sequencer to the sequencer of the digi 001 sequencer?
Is it possible to to transfer my sequences I made in my roland xp-80's sequencer to the sequencer in pro tools le so that that the note data is actually in the computer and will just control the xp-80's sounds?
Is it possible to do it by way of midi cables and not smf on a floppy disk?
(I don't have a floppy drive,mac g3 b&w)
Thanks,Anthony
Anthony
Anthony
Help Importing External Sequencer Data into PTs MrWillsi3 MIDI 11 01-06-2010 11:43 AM
ME & Digi SEQUENCER don't get along.....need alter DVDave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-22-2005 05:38 AM
Linking 2 Digi 002 & Extetnal Sequencer...??? suenos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2003 04:51 AM
MIDI sequencer for Digi 001 tallbobsmoke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-07-2002 12:13 AM
syncing from sequencer to digi 001 guitarboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-17-2002 11:00 AM
