Old 08-13-2012, 02:37 PM
Artist PM's Avatar
Artist PM Artist PM is offline
Default Workaround for Mackie Control/HUI prefs on 10.8
Go to HD/Library/
You'll have to hold down Command and go to the Finder menu item: "Go" to get to Library.
Right click on the Library folder
Choose “Get Info”
On the bottom of where it says Sharing & Permissions:
Make sure Everyone is set to “Read & Write”
Double click on the Library folder
Right click on the Preferences folder
Choose “Get Info”
Make sure Everyone is set to Read & Write
Drag and drop Live/Reason, etc into the EUCON preferences Panel
Choose Mackie Control as the protocol
Restart system
Old 09-05-2012, 06:18 PM
battledog battledog is offline
Default Re: Work Around for Mackie Control/HUI prefs on 10.8
This 'fix' does not work for me. I even tried making every library folder read and write. When I restart my computer every thing has disappeared.
I am running Mountain lion. It is extremely disapointing that I cant use my Artist Mix with anything but pro tools
Old 12-14-2013, 05:55 PM
Antonio Escobar Antonio Escobar is offline
Not working here either
Old 05-04-2014, 02:59 PM
kyo_acid kyo_acid is offline
This is not encouraging. I have just been reading up on this issue as I 'was' looking to get an Avid Artist Mix, I would really love one.
Old 05-13-2014, 03:44 AM
If your not planning using EuCon ONLY with Pro Tools, it's not a good momento for this system. BIG issues with Nuendo/Cubase, Mackie emulations, driver unstable, etc.
MC Control Prefs & Preset Question KeyplayerG Artist Series 7 09-05-2014 06:32 AM
Workaround how to reconnect MC Control (Macke) djmichaelwenz Artist Series 0 10-01-2013 08:56 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Can the Mackie Control extender work w/o Mackie Control? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2003 08:52 AM
a note from Mackie about the Mackie control remote Pro Tools TDM Systems (Mac) 100 11-02-2002 12:25 AM
