  #51
Old 11-04-2017, 09:54 AM
TimmyMac TimmyMac is offline
Default Re: EUCON 3.7 crashes immediately!!!!!
Originally Posted by EddieJones View Post
This isn't the same issue as the original post that was fixed and Mac only.
The EuVkbd.sys file is a virtual keyboard driver (softkeys etc) Did you install any new hardware or software around the time the crash started to happen?
I would stick with 3.7 for trying to fix this but first, uninstall whatever's on there now.
Then open file explorer and select the c: drive type EuVkbd.sys into the search and see if any are left behind (let the search finish, it take a while). Try and delete them. Then reinstall v3.7
That worked! That file was in a few directories under System32. Removed and install went through. Looks like I'm back in business!! Thanks a bunch!!
EuControl 3.7 crashes immediately with PT moranibus Avid S1, S3, Dock and Control App 11 10-19-2017 08:52 AM
Pro Tools crashes immediately Rich Crescenti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2010 03:44 PM
PT8 M-Powered Crashes Immediately chrisconover Pro Tools M-Powered (Mac) 10 05-31-2009 10:19 PM
LE 6.4 crashes immediately with 002R j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-27-2005 06:37 AM
Mac G4 Crashes Immediately...I'm really new to this luapfitz Pro Tools TDM Systems (Mac) 2 09-04-2000 05:40 AM
