Old 06-10-2017, 03:50 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default D-Command replacement
Hi all!
Question for the D-Command users here. When and if the time comes to replace your D-Command, what would replace it with? Seems like there is no current lateral move offered by Avid. S3 is clearly a step down and the S6 is an expensive step up.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 06-10-2017, 08:43 AM
Watagushu2013 Watagushu2013 is offline
Default Re: D-Command replacement
I am in the same boat here.
The s6 M10 is the natural upgrade path for d command users, but the lack of tft's or screens are why the upgrade to S6 m40 is the more desirable and more expensive.
Old 06-10-2017, 10:11 AM
Marsdy Marsdy is offline
Originally Posted by Will Russell View Post
Hi all!
Definitely the S6 M10. A 16 fader M10 is more expensive but roughly in the same ballpark as a 24 fader D-Command. An M40 with displays is massively more expensive. The displays look fantastic but personally I don't miss something I've never had! 16 faders sounds like a downgrade but the way VCA spill, Layouts and Track View session navigation on the touchscreen work is impressive. You might not even miss 8 faders. However, if you want the S6 to behave like a D-Command with dedicated EQ and Dynamic sections you may want to add two Knob Modules and use them in "Expand" mode. Unfortunately this would bump up the price quite some way beyond a 24 fader D-Command.
When I looked at moving from a C|24 to the S3 two years ago, I felt the S3 was a significant downgrade in many respects. I haven't followed how the S3 has developed since though.
Dave Marsden
UK
Old 06-10-2017, 11:01 AM
YYR123's Avatar
YYR123 YYR123 is offline
Wonderful informative post Marsdy.
The problem I don't like about that upgrade path is Eucon....it's another level of software that has bugs and has to have Avid troubleshoot and fix.
That comment should read as "Eternal Subscription plan required".
Think about the simple request of the the velocity settings of the rotary encoders for the artist series surfaces
Digidesign Icons could be parked tomorrow and work great as is...i don't know if Eucon will ever that stable and bug free....or how long it will take to get there.
Daniel
Old 06-10-2017, 11:06 AM
I honestly wouldn't worry about EUCON. S6 EUCON is a totally different beast to S3/Dock/Artist EUCON. They are in no way interchangeable, one won't work with the other. Any criticisms of S3/Dock/Artist EUCON simply don't apply to the S6.
Dave Marsden
UK
Old 06-10-2017, 11:37 AM
Drew Mazurek's Avatar
Marsdy,
Does the S6 require its own yearly plan in addition to your PT plan? Or does your PT plan cover S6 updates?
thanks.
www.drewmazurek.com
Old 06-10-2017, 12:40 PM
Originally Posted by Drew Mazurek View Post
Marsdy,
thanks.
It does require a yearly plan if you want software upgrades and it's not cheap. The MTM master module, (the one with the touchscreen,) is the brains of the system and costs £460 a year without tax. That includes a 24 hour swap out of a faulty module. You have to get the plan if you want software updates but it's not obligatory if you're happy with the software as is. I don't think there's a penalty for reinststing a lapsed plan.
A plan for a 24 fader fully loaded M10 is £1749 per year ex-tax including module swap out and the Xmon.
Overpriced IMO but that's Avid!
EDIT: Forgot to say - These prices are what I paid in the UK as of January this year.
Dave Marsden
UK
Old 06-10-2017, 01:19 PM
Wow!!
Thanks for the detailed response.
www.drewmazurek.com
Old 06-11-2017, 05:33 AM
OK. This right here is why I'll never get one. Together with the PT HD plan, that's 2k a year just to get software bug fixes, updates and tech support. Ridiculous.
Will Russell
Old 06-11-2017, 07:40 AM
I don't think it's quite that much for a basic plan including PT but it certainly sticks in the throat when you hand the money over!
Dave Marsden
UK
Command 8 Fader Replacement jazzer61 ProControl, Control|24, Command|8 6 01-14-2013 07:44 PM
When will there be a 003 or Command 8 replacement? De93 Pro Tools 10 5 11-07-2011 09:56 AM
Replacement knob for Command 8?? Livin' Proof ProControl, Control|24, Command|8 0 07-15-2010 09:57 AM
Command|8 Potentiometer Replacement Siegfried Meier ProControl, Control|24, Command|8 0 01-17-2009 02:23 PM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
