Old 10-13-2019, 08:27 PM
paul_g's Avatar
paul_g paul_g is offline
Default PT 10 with L6 HX Stomp
Hi folks, is there a way I can use both my 003 and HX Stomp at the same time?
ProTools does see the HX Stop in the Playback Engine window, and if I select it, PT restarts, then I can record to the track directly from the HX Stomp to PT via USB. The 003 still remains in the session (meaning, it doesn't go off-line), so there is something preventing the audio from going from PT to the 003 to the monitors.
With my Eleven Rack I can use both the Eleven & 003, has anyone been able to do that here with L6?
Seems like I'm missing something here... any thoughts? Otherwise, I'll have to do it the old fashion way, and just run L/R out into the 003 or my PreSonus Digi Max FS. This is a bit of a pia because I use the Stomp on my pedal board and I'll have to always pull the outs.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Stomp Box plug-ins Crazyuncle Pro Tools | Intro Discussion 2 04-21-2017 05:51 AM
where are those stomp boxes .... MYNAMEISNOBODY Eleven Rack 2 09-20-2016 07:06 AM
Stomp Box Effects guatamas AAX Plug-ins 8 11-16-2015 02:09 PM
New Stomp box plugins? audioluche Pro Tools 12 21 10-09-2015 09:46 PM
Rumor - can you stomp it for me? IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 03-30-2004 06:21 PM
