  #361
Old 04-22-2012, 10:02 AM
Clemdog76 Clemdog76 is offline
Default
How do I treat or correct the room? How do I use audio analyzing tools?
  #362
Old 04-22-2012, 10:09 AM
Default
http://soundcloud.com/prone11/hera-nor-harem
  #363
Old 04-23-2012, 12:33 PM
RegenerationMix RegenerationMix is offline
Default Re: Mixing help?
Check out this youtube video series for home recording studio treatments. You should get an idea for treating a room.
http://www.youtube.com/watch?v=02qpJt0hsL0
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
  #364
Old 04-23-2012, 12:37 PM
guitars and lead vocals are good, the drums are buried Especially the kick and snare and the bass isnt defined. the backing vocals are not distinct. dont know if you wanted them that way or not.
Most of the problem here i think is the drum sounds.
Chris
  #365
Old 04-24-2012, 12:12 PM
Default
Thanks for the honest feedback I appreciate it and thank you for the video link.
  #366
Old 04-24-2012, 01:44 PM
Default
One more thing concerning monitors. Some have switches on the back. Yamaha nearfield reference monitors for example. What are they for and in what circumstances do I use them?
  #367
Old 04-24-2012, 02:36 PM
my Mackie monitors have switches for where the monitors are in the room,
backed up against a wall, on a desk in the center of a room, or in the corners of a room not on the desk. They also have switches for low freq, high freq and acoustic freq. If your mixes are too bright or to dull, you can decrease or increase the high freq, I can also adjust the input sensitivity and the power standby mode.
The monitors adjust to how they are in the room to help you tune the monitors to how the room makes them sound.
Most quality monitors will have some switch settings on the back. The manual that comes with them will explain the switches. Monitor brands will have different switches and adjustments.
Chris
  #368
Old 04-25-2012, 11:19 AM
Default
Thanks guy. Makes perfect sense and really just substantiates what I thought. Guess the best thing to do is listen to my mixes in my car-Adjust the monitors accordingly that's what they say. In most cases I'm guessing you want to use the balanced out on your interface. Still a bit of the learning curve. Don't know anything about input sensitivity and all those other things you mentioned. my interface has quarter inch balanced outputs. I'm guessing you just use a stereo ring sleeve or some kind of adapter would be nice to know what I need to keep them outputs balance-guessing some monitors have quarter-inch balanced inputs as well as XLR.
  #369
Old 04-25-2012, 12:11 PM
my monitors have XLR balanced inputs, 1/4 inch inputs and RCA. I use XLR to 1/4 inch cables to go from my interface to my monitors. The XLR plugs into the monitors, the 1/4 inch end plugs into my interface.
Balanced is best i think.
Chris
  #370
Old 12-02-2012, 02:55 PM
WreckGranados WreckGranados is offline
I Also have a problem mixing my vocals. Can anyone give me any tips on how to properly? I only use the EQ, Compression, And Reverb... Here is a link to the song i did..
http://soundcloud.com/wreck-granados/not-finished
Mixing down to an MP3 JhunBorruel Pro Tools 10 3 05-05-2012 01:02 PM
Mixing for DVD compared to mixing for Broadcast Taddy Post - Surround - Video 8 09-05-2006 12:02 AM
Steps in pre-mixing and mixing: How do the pros do it? [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-29-2003 08:28 AM
Jackson’s Guide to Better Mixing through “Mixing” BigRedButton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-08-2003 07:32 PM
Mixing to CD B.Ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2000 01:59 PM
