Old 08-26-2018, 05:39 PM
HeniousDelVon HeniousDelVon is offline
Default Command 8 midi
If the command 8 has the be the only midi in PT how can i get my MPC to be the master so i can track in PT?!. Sorry if this seems basic but i switched over from a PC
Basically i want my MPC to be the master but i wanna use my command 8 to mix and edit
Old 08-26-2018, 06:15 PM
BScout BScout is offline
Default Re: Command 8 midi
Well, this isn't true:
http://www.akaipro.com/support/kb/ar...with-pro-tools
Old 08-26-2018, 06:21 PM
I worded that wrong it has to be the main midi controller
PT 8HD (midi i/o and Command 8)..... Sixstringer7 Pro Tools TDM Systems (Mac) 1 04-28-2014 09:38 PM
key command midi editor mafiacondon Pro Tools TDM Systems (Mac) 1 11-28-2011 05:35 PM
No midi keyboards in PT 8 on Command 8 dsetaro ProControl, Control|24, Command|8 0 12-23-2008 11:39 AM
Can I use Command 8 and Midi i/o at the same time? Hp trigger Pro Tools TDM Systems (Mac) 1 06-01-2007 11:00 AM
command|8 and midi waskull ProControl, Control|24, Command|8 1 08-09-2006 09:01 AM
