Old 12-05-2018, 04:35 AM
gafyn gafyn is offline
Default AAF out of sync from Media Composer to Pro Tools
We've been working with Avid media composer and Pro Tools for years, and everything has been working fine.
Now the Editors want to update from Media Composer 8.4.5 to 8.9.4.
We have done an AAF export test and a lot of the audio is out of sync; random times like 1 or 2 seconds out.
We use Pro Tools 11.3.1 and all projects are 25 FPS.
All on Windows PC
Is there any reason why this is happening? Is there a fix?
Thank you all.
Gaf
There is no Spoon
Old 12-06-2018, 08:30 PM
laki laki is offline
Default Re: AAF out of sync from Media Composer to Pro Tools
Hi Gaf,
I have had this problem when the AAF has mixed bit rates and sample rates in it.
The only solution I could find was to open the AAF as a stand alone first (by double clicking it). Then Importing into PT.
Not sure if this is the same issue but give it a shot!
Old 12-07-2018, 02:42 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
You need to upgrade to PT 12.5 or above.
There are a couple of threads about this MC bug.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
HTML code is On
Media Composer 8 Satellite Sync Lock Errors danbrennan Post - Surround - Video 7 06-14-2015 06:41 AM
Media Composer Extract in Pro Tools? Mack Truck Tips & Tricks 2 01-06-2014 12:30 PM
Pro Tools 10 and Media Composer 7 audioczar Pro Tools 10 5 10-17-2013 02:41 PM
