Old 10-10-2016, 02:22 AM
nofx1609 nofx1609 is offline
Default Temporary Grid Mode when holding down Command in Pro Tools 12.6
So this seems to be a new feature in 12.6 whilst in shuffle or slip mode and it's a nice idea and all but is there any way to disable it? Because it's kinda screwing up a work flow of mine that I use everyday.
Alternatively is there any other way or suggestion to clear a selection from the left side of the keyboard other than Command-B (not involving cmd)?
Old 10-10-2016, 07:52 AM
Drew Mazurek's Avatar
Default Re: Temporary Grid Mode when holding down Command in Pro Tools 12.6
Might want to read through this.
http://duc.avid.com/showthread.php?t=384591
www.drewmazurek.com
Old 10-10-2016, 09:47 AM
The Weed's Avatar
The Weed The Weed is offline
How about Delete?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-10-2016, 10:19 AM
jscomposer jscomposer is offline
Yes. Reinstall 12.5.2 or whatever version you were using before you updated to 12.6 without reading the release notes.
Old 10-12-2016, 03:16 AM
Originally Posted by The Weed View Post
How about Delete?
Delete's on the wrong side of the keyboard. It's a workflow/rate thing.
Old 10-12-2016, 03:24 AM
The release notes would not have made me realise that quickly making a selection and clearing with Cmd-B the may briefly overlap in time every now and then thus compromising the selection and clearing the wrong area, slowly making me die of frustration.
But thanks for the reply. I'm gonna take it as a no, there's nothing I can do about.
Old 10-12-2016, 06:10 AM
Carl Kolchak Carl Kolchak is offline
Make sure you are in "Command Focus" mode (the little "A...Z" box in the top right of the edit window - as opposed to it being highlighted in the clip list, or group list).
Just hit "x" to cut the selection.
Old 10-14-2016, 05:51 AM
Thanks for the suggestion. Unfortunately i very often have something in my clipboard to paste so x won't work. Also because I do 100s of these cuts it does clutter the clip list with crap if I use x instead of cmd-b.
Old 03-16-2017, 01:09 PM
Spanzor Spanzor is offline
anyone find a way to disable this yet? It's especially irritating when trying to trim within fades, as when the fade gets pretty small the trimmer stops moving inward towards the other side of the fade. I used to use the command key in slip mode to work around this. Now that it's changed I definitely notice it.
Old 10-09-2017, 08:07 AM
Verbcrunch Verbcrunch is offline
it’s “COMMAND” “z”, “x”, “c”, or “v”.. in about every piece of software we use. But do that in ProTools, my selection automatically snaps to the grid right before I copy or delete - so I end up with upcuts or extra space - NOT what I selected, sometimes I don’t even realize it happened. So for me it means “undo” go back, do over. Time = wasted.
The reasoning is you don’t need to hit the “command” button in PT keyboard focus mode - you just hit the “x” or “c” - no modifier key needed. But muscle memory is strong - I have to be really conscious of NOT hitting “command”. Before there was no consequence if you did, now there is.
I’m mostly editing voiceover for radio promos and have no use for this new feature, when I want things to snap to the grid I hit “F4” and work in Grid mode.
Thanks for reading, hoping Avid would consider enabling us to turn off this feature.
Grid Mode - Command Click - Smart Tool txm macOS 0 10-11-2015 10:10 AM
Grid view in grid mode vs in shuffle mode ryancousins Getting Started 4 04-13-2013 10:41 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
Putting selector temporary out of grid mode ? andre tchmil Tips & Tricks 3 02-25-2006 11:57 AM
Grid Lines - Slip Mode vs. Grid Mode Mt.Everest Pro Tools TDM Systems (Mac) 24 02-20-2006 08:38 AM
