Old 09-17-2020, 03:31 PM
Ben Jenssen's Avatar
Default Re: Sudden Issue With Playback on One Session
Back then I think it had something to do with PT adding "minus time" to the timeline, to give flexibility.
I think I found a workaround, like zooming out and moving clips one hour, or something like that. Maybe there was a way to move start time, I can't remeber, but keep the faith. This is not the end.
Old 09-17-2020, 03:37 PM
Snafu Snafu is offline
I can change the session start to -1 hour, or to zero, but it's still not playing anything or linking cursor to playing I don't understand how it's now carrying across sessions...
Old 09-17-2020, 03:40 PM
OK, loop playback is grayed out!! Is this a hint to any ideas???
Old 09-17-2020, 03:44 PM
Do you use a mouse to select a portion of the timeline?
Also: what version PT and OS?
Old 09-17-2020, 03:46 PM
I do use a mouse. I'm on Pt 8.05 and Win10, have been for a while. Just noticed that its the only thing that's enabled on my other sessions that i can still edit that I can't enable on this one.
  #16
Old 09-17-2020, 03:50 PM
You should know that PT8 is not compatible w/W10. Not even PT10 was. I'm not saying that's your problem, but well...
  #17
Old 09-17-2020, 03:57 PM
It seems odd to suddenly strike like this...maybe if i had updated or something i would understand but midway through a session? And with all my other sessions still working? I feel like it will be the thing you fixed!
  #18
Old 09-17-2020, 04:06 PM
I'd say, if you try to run PT8 on W10 then expect odd things to happen! They weren't made to play toghether.
Did you try to zoom out, locate the clips, select the portion, and play?
  #19
Old 09-17-2020, 04:14 PM
I'm about to reinstall in case it helps...wish i could revert to Win8 regret going to 10 massively but really terrible with computers and don't know how. Will see if I can run PT on compatibility mode...but still my instinct says if I've had 9 months with no problems (outside using the silent way plug in) it seems weird to go to completely non functional. I do appreciate your time and don't mean to dismiss that it could be that, just don't want to give up I guess and given that you faced such a similar problem i still have hope.
The clips are locateable and selectable, but nothing plays (also on new sessions now nothing imported plays...my old sessions all work!).
  #20
Old 09-17-2020, 04:28 PM
I think, no I'm certain, that you should create a windows 7 boot disk (google it) and install PT8 on that. PT8 was made for W7! Then you'll have a predictable setup, and I think a good chance to recover the session. "Clean install" as they're called are the clue to have "fragile" apps like PT work good.
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Sudden issue with 003 and low latency Linusoli Pro Tools 10 0 08-27-2013 02:48 PM
Crazy Session - Playback Timing Issue Craiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2010 02:39 PM
Sudden Issue Opening ANY .ptf in 7.4 stackjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-12-2008 07:15 PM
no playback all of a sudden sojay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2002 09:50 AM
